Question about Whirlpool Dryers
How to put new belt on - Whirlpool Dryers
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 66 Answers
Remove back, loosen motor bracket, remove belt, put new onw on, belt size on belt, move motor on braket to put tention on belt tighten motor bracket
Posted on May 08, 2010
How to put a belt on
You put a 3/8" ratchet in the tensioner arm. Looking at the side of the engine to the passenger side of the van, the tensioner is at the top of the engine towards the back. Twist the tensioner to allow the old belt to be removed, Install the new belt following the same path. There should be a sticker on the belt guard by the power steering pump. The belt will fit smoothly on all the pulleys. Pay attentions as some pulleys have the belt groves facing in, some have the belt groves facing out.
IMPORTANT - When you do this, put all the keys for the car in your pocket so no one can try to start it.
Oct 18, 2012 | 1999 Pontiac Montana
HOW TO PUT A BELT ON A 1998 CROWN VICTORIA
  • I have posted the diagram you need to reference. In red I have indicated the tension pulley.
  1. Take a socket and ratchet (breaker bar works best) or a wrench and put it on the bolt of the tension pulley.
  2. Now you want to tug to the left until the tension on the belt loosens and then carefully let the tension pulley go back to it's normal position.
  3. Now take the old belt and compare it to the new belt. Make sure the tracks, length and width match up.
  4. Put the new belt on on the pulleys as indicated in the diagram leaving the tension pulley for last.
  5. Now put your ratchet or wrench back on the pulley and pullback on it again and put the belt on it.
  6. Now start the engine and inspect the belts rotation.
  7. If the old belt did not completely snap the I would throw it in the trunk. It beats sitting on the side of the road sometime should the new belt break.
  8. That's it, job complete.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 19, 2011 | 1998 Ford Crown Victoria
How do I put the serpentine belt back on a 1998 saturn sl2 after I have installed a new alternator
there is a little stick man illustration sticker under the hood showing how to release belt tension by moving the tensioner arm. if the serpentine belt is still on the lower pulley then put the belt on everything except the tensioner, then move the tensioner arm as needed, put the belt in there and release the tensioner arm. most likely going to need two people to do this.
if the belt has come off the lower pulley then you are going to have to remove the service panel behind the right front wheel and put the belt back on lower pulley, then do as above described. this would be a great time to put a new tensioner, a new serpentine belt, and a new "dog bone" motor mount on as it will all be right there to work on with that service panel out.
Apr 03, 2011 | 1998 Saturn SL
New Serpentine Belt Causes Squeeling. Added gobs of belt dressing, still squeels. Old belt was only half a belt--totally worn out. New belt is therefore tighter and putting more force on pulleys. Do I...
Take off the new belt ... toss it ... get a new belt ... before you put it on ... clean all the pulleys twice ... final cleaning should be alcohol.
Oct 27, 2010 | 2003 Mini Cooper
Put a new timing belt on, car still wont start.
hi put the #1 piston up with the camshaft lobe up so the valve will seal the compression in the chamber
Mar 26, 2010 | 1989 Mazda 626
How do you install a new belt? its hard to fit around !!
Youmust loosen the motor bracket bolts and this will allow the motor to swing. Put belt on the motor pulley and feed the belt onto the large drum pulley and at the same time turn the drum pulley so that the belt pulls onto the pulley groove. Put some tension on the motor to tension the belt - not too much tension though. Holding the motor & belt tension, tighten the motor bracket bolts - job done. Should take no more than twenty minutes to complete.
Apr 14, 2009 | Washing Machines
Cannot fit a belt to hoover whirlwind
on the top of the base you will see three slots on each side of the top of the base the middle slot has a screw one on each side take those out and the cover will lift off.you will be at the roller and belt.lift up on the roller and put it on the side .you must clean the old rubber left on the motor shaft first before installing the new belt.otherwise the new belt won't last long.slip the belt over the motor shaft then put your roller brush through the new belt.you might have to pull forward on the roller to get it in place because of the new belt ,they are a little tight at the beginning.then alighn your roller ends and put the roller back in their slots.turn the roller by hand till the belt in in the middle of belt guide on the roller .now you can put the cover back on .then your in buisness.
Apr 10, 2009 | Hoover U5753-900 WindTunnel Bagless...
TROUBLE FITTING NEW BELT
i put the belt on large wheel then with a large Phillips screwdriver
though a socket slightly larger than the motor wheel put the belt around the socket on the screwdriver and put the driver in the small
hole in end of the motor wheel,lever the belt and slide the socket with the belt on down to the wheel ,push the belt over the socket onto the
motor wheel this my take 5-6 atemps but ive done it about 5 times
Feb 05, 2008 | Washing Machines
Dryers Logo
103 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
