Cutting plotter ROHS 720 I have this driver jt720... This is a update on a problem,, manufacturer is [ROHS 720]Shanghai Jintian useing driver.. JT-720 It came with Artcut software and im Running Win 7,, tryed win xp but nothing, With win 7 i can get i to work but... it bugs out after 25% sometimes 50% and trys to go to far to the left, so far the belt jumps and i have to push the reset to stop it.. if it have it cut the name "MATT" it cuts "MA" then bugs out
  • Matthew Albert
    Matthew Albert May 13, 2010
    ty
    will try xp again
  • 12,061 Answers
I have serviced these "Sign Robots" many many times over the years although I cut my teeth on Gerber' Cutters. Anyway, they are all very much the same, and are dependent on Drivers, and Ports. Most often they worked under Windows XP SP2. Now usually the "Language' it talks to the "Plotter/Cutter.is in HPGL. or Gerber Files. It is most likely doing that, cutting off, due to the serial port, and the way in which, Win 7 handles the port. you said you tried XP, and it didn't work? that is very odd, as this is the very, the only program that I would expect it to work with? However. another reason that it may cut off, is MEMORY, you need lots and lots of memory, so you could try increasing the amount of RAM, also the "Spooling" area maybe needed to be increased, and using that ArtCut software, too, maybe it would pay to run as Administrator, and also set compatibility mode for that too. Also ensure that the Plotting software is the ONLY thing running, including background software. Also, you may wish to try Compatibility Mode for XP SP 2. when running and installing the software as well as setting compatibility. mode too Also install everything as Administrator too. Check your serial plug wiring especially the earth connections. I mean basically, it is just a plotter, any program, that "Talks" in the "Language' of the "Plotter/Cutter, will work, you just have to make sure, that the serial ports settings, baud rate, stop & start bits, and number of bits too, are all set correctly. Always use the proper cable too. If you can, you should try to contact the manufacturers, and see if they can supply you with up to date drivers, and software for your unit. Sometimes, a new software and new drivers make all the difference.
http://www.cadlink.com/support_train/forums/viewtopic.php?p=5695&sid=c53e46576aa233a9f2516205d356d8cd
www.mbkpinternational.com/book2.pdf
www.grs-systems.com/images/SignTools3_A.htm
http://www.t-shirtforums.com/vinyl-cutters-plotters-transfers/t82733.html
http://www.google.co.nz/search?num=100&hl=en&ei=uCPlS_yWMpGMswOI6fTRCw&sa=X&oi=spellfullpage&resnum=0&ct=result&cd=2&ved=0CBgQvwUoAQ&q=Artcut+vinyl+software+similar&spell=1
Ok, check out these links above, the first one, is alternative software and upgrades software, above that, are some more help forum sites, then sign tools, than a manual for your plotter.
Posted on May 08, 2010
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
What is AppHangXProcB1 in my cutter plotter
What kind of plotter. Reading the error it appears that some process is freezing up. This can be caused by a corrupt print job, bad driver. First step you want to take is to update the firmware on the plotter.
Jul 23, 2016 | Office Equipment & Supplies
SUDA SD720 CUTTING PLOTTER DRIVER
Dec 04, 2010 | Office Equipment & Supplies
I have a cutting plotter,, its a ShanghaiJintiar JT720.. works with Artcut6, <--this is what came with it. I want to use corelDraw with this plotter.. looking to make lettering with background...
basically you set corel draw to the paper size (vinly) your using.. click outside the page and set it using the selector on the tool bar..
once thats done,, click print,, select your plotter,, set your properties your using if not leave at default,, hit print..
Jul 12, 2010 | Sport & Outdoor - Others
How can i utilize the dell 720 printer on my lap top with vista software
Just update your driver by downloading printer driver support for Vista on your manufacturers support site. From there you may have to download Printer driver for Vista and Patch/Upgrade.
Run Patch/Upgrade first (requires you to restart computer) before installing the printer driver.
Hope this helps. Thank you for using Fixya.
Jan 08, 2010 | Dell Office Equipment & Supplies
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
1,924 people viewed this question
jasbo
jasbo
