Question about Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive
External Hard Drive stopped working
I have a Toshiba external hard drive. It was connected to my PC and then for some reason the device no longer appears on My Computer. I've changed the cables, used different USB ports and the PC still doesn't not detect the external hard drive. I have also checked the USB ports w/a flash disk and that appears on the My Computer page as it should. When I plug the hard drive into the USB port the hard drive lights up like it is getting power, but I still can't get it to appear on my list of devices w/removable storage on My Computer. And sometimes when I plug in the external hard drive and try to access My Computer it freezes. I reboot the PC and still no joy. Please advise.
    Sergeant:
    Champion:
  • 236 Answers
U might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
Posted on May 08, 2010
Imicro IMBS35G-BK external drive stopped working. computer will not read it.
Try a different cable. If that doesn't work buy a new enclosure and install the drive.
Apr 03, 2014 | Imicro IMBS35G-BK 3.5 inch USB2.0-SATA&IDE...
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
My verbatim external hard drive has stopped working. I plugged it in to a computer at work which cam up with "power surge" the light no longer comes on and it is not being recognised in my system device...
Disassemble the external drive and install the hard drive in a pc or place in a generic external drive you can purchase without a drive inside, then you can get access to those files again. The External drive interface has failed not the drive itself.
Oct 06, 2013 | Verbatim SmartDisk Firelite Portable USB...
Help! XP stopped recognizing my external hard drive. It has worked fine for two years and then suddenly: My Laptop no longer "dings" when I plug in the external hard drive. There are no unknown...
No question is silly dear, problems are there and we are in this site to help.
Yes, you mentioned that the said device works fine with your desktop, then it is probably not the problem with your device. You have also said that your tried formatting the os. Good.
Hope your pc, laptop and the memory device are disinfected with a good, licensed and updated antivirus.
Check, if Universal Serial Bus Controllers (corresponding to the nos. of total usb port present in the machine) are present and enabled both in the device manager and the bios as well and set to Hi-Speed if it is Full-Speed.
Well, have you tried formatting the memory stick/device? Format it and see if it works.
Next, please change the usb connectivity cable using/attached to the device and see.
Another thing while connecting an external storage device like ext-hdd. The external usb storage devices that gets connected with a usb cable, in some rare cases needs to be connected as a usb-master or usb-slave [you can see many external usb drives comes with a splitted or dual usb port connector cable, this is either for connecting two usb device or to connect as master when used as a single drive], therefore use such cable to connect and use alternated ports, and see which works.
Now, if all above fails, it then might be the problem with your external drive, i guess.
Best to seek help of your system admin/vendor.
Oct 16, 2011 | Microsoft Windows XP Professional
I have a 320gb toshiba external hard drive, i've been using it around 3 years without any trouble. A few days ago i lost the cable connecting it to the PC. I bought a few cables but no use. Doesn't...
This is because there is a connection problem between the external drive and the computer. If you have changed cables to no avail, you can open the casing of the external drive where you will find the hard disk inside. Unplug the two cables connected to the harddisk and replug it after a minute. Then try again. If it still does not work, then you need to buy just a usb enclosure and plug the harddisk there to be able to use it again.
Hope this helps. Thank you for using FixYa.
Jan 13, 2011 | Toshiba 120GB USB 2.0 Portable External...
I cannot connect my external hard drive through the sata port
Install the external hard drive into an USB hard drive adapter case. You can then connect this into the Toshiba's USB port. The Toshiba will see this as an external storage device.
Jan 08, 2011 | Toshiba Satellite Pro M300-S1002X Notebook
External hard drive has been working fine but now doesn't appear
Have had issues with an external Toshiba hard disk not showing up as well.
Found a solution here:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Hope that can help you too.
Apr 02, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
External IDE enclosure problem
here's what a sata hdd connection looks like
here's what a IDE hdd connection looks like
here's a page that shows them side by side
Hopefully that should help with what you have there.
Jan 21, 2010 | Toshiba Satellite 2455-S305 Notebook
MY EXTERNAL HARD DRIVE KEEPS SUTTING OFF. WHY IS
Check your powersaving settings in windows. Most external devices will be automatically set to conserve power when not in use. An external hard drive is considered not in use when you are not actively accessing data on that drive.
Oct 12, 2009 | Toshiba 120GB USB 2.0 Portable External...
External hard drive shown as portable disk and does not work
hi
i think the hard drive is ageing,
if you are past warranty try to open up the casing and try to see if you can connect the HDD to connect individually else where (like with another casing or Laptop PC) if still not connecting then the problem is with the HDD
else the problem may be with the casing
cheers
pls rate if this was any help
Jul 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Toshiba 120GB USB 2.0 Portable External 120 GB Hard Drive Logo
747 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
