Question about Micro Innovations IC150C Webcam
Have moved. no disc. no setup.exe file in
Have moved. no disc. no setup.exe file in folder. etc...
  • Micro Innova... Master
  • 10,322 Answers
1st You download Webcam Driver. Innovation IC 150C Cam Driver After this install the Webcam driver in the system.
Installation of Webcam Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Posted on May 15, 2010
Setup cannot find Office.en-us\dwtrig20.exe
Go the folder and open the file whichever your setup cannot find and then retry.for example if your setup cannot find dwtrig20.exe, find it in the setup folder and open it..then try installing it again. in most cases, the setup will not be able to find 2 files. open the two files whenever the setup cannot find them and then install.
this will surely work :)
Jun 08, 2011 | Computers & Internet
Driver will not insal
If you are having problems installing the disc what you can to is:
- insert the disc on the disc tray ( do not install right away cancel the autorun) - go to my computer (computer) then explore the disc - then create folder on your desktop ( right click on a clear space the select new > folder) - name it as roxio - copy all the contents on the disc ( highlight them all then copy) - paste the file that you have copied inside the folder that you have created on the desktop - remove the disc in the disc tray - then go to the roxio folder from the desktop and locate the filename setup or setup.exe then double click it - run the installation
Cheers . . .
Feb 07, 2011 | Symantec Roxio Easy VHS to DVD
My flash drive 16 gb sandisk cruzer u3. when i insert in Laptop it opens but file not showing. showing run launchu3.exe. how can i get launchu3.exe? i checked prpperties all file inside but not...
I have the very same flash drive.
The file you refer to "launck3.exe" is a file compression utility from Sandisk. It works well but I don't use it. I placed the drive into a USB slot and chose "open folder" in the options not "auto run". I then mad a new folder called "old cruzer" and moved all of the files in the root of the flash drive, to it. Leaving an nice empty drive to copy and paste to.
I hope that helps.
Oct 22, 2010 | Computers & Internet
Installing War Front: Turning Point in Win7
Well you have prob tryed this but ill say anyway.. Click this in the following...
Start--Computer-Disc Drive (Etc)- Then look everywere on the cd files lol XD
It IS in there so keep looking.. Look in every folder. But try getting another version of the game.. Sounds stupid but tht could be the problem tht the dics data is buggered ..
Cheers and sorry i cant help anymore thnx.
May 07, 2010 | CDV Software War Front: Turning Point for...
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the wxp10.zip file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here > http://www.utorrent.com/
DL and install.. then click on torrent link and it will DL.
http://thepiratebay.org/torrent/3820108/Windows_XP_Live_Edition(Run_Windows_from_CD)
here is a link how to make it.
http://www.intowindows.com/how-to-create-live-usbcddvd-of-vistaxp/
Feb 01, 2010 | Microsoft Windows XP Professional SP2
The install shield doesn't finish working
Try copying the files on the disc to a folder and run them from there. Open the folder you saved the files in then double click the setup.exe icon and see if it completes the installation. If that does not work then try downloading the files from the radio shack web site.
Sep 08, 2009 | Radio Shack VGA PC Camera Webcam
Setup cannot find the required setup controller file.
Download the PowerISO file and Install. Once the system reboots, go to My computer. Now you can see a new CD Drive. Right Click on it and select PowerISO-> Mount image to Drive. Now browse option will open and select the disc Image file and click open.
After that Right Click on the New Cd Drive and click on open and the setup will run...
Aug 02, 2009 | Microsoft Office 2007 Basic for PC
I'm unable to install Mortal kombat 4 in Windows XP SP 2. As soon as I activated setup, it exits with the error Msg "Start Menu Error". Please help
I've been trying to solve the same problem. Here's a solution I discovered that worked for the same problem in Vista; it may work also for XP.
To install and play Mortal Kombat 4 in Vista:
Click setup.exe.
Choose installation folder (create it later).
Get error message.
Do not click "Clean up."
CTRL-SHIFT-ESC and kill setup.exe process.
Create installation folder (selected during setup).
Copy all files in DATA folder on CD to installation folder.
Rename MK4.exe to Mortal Kombat 4.exe.
Install patch (optional).
FIGHT!
Regards,
Amillennialist
Feb 01, 2009 | Midway Home Entertainment Mortal Kombat 4...
Let's Ride Corral Club will not run
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
The same set of steps can be used for installation of older games installation on Windows Vista.
Nov 11, 2008 | ValuSoft Let's Ride: Corral Club for...
Set up installation for 5000md xp will not start up
Cut or copy the driver zip file and go up a few levels and paste it on the desktop or in a folder on the desktop or in a folder in my docs and unzip ALL the files to this new folder and run setup. I had same problem. For some reason if you save the file 3-4 or more folder inside a folder inside a folder ect (you know...try to be organized?) it won't run. Whats more if you were to just move the SETUP.exe file and not the other folders (such as DATA) the install would start asking you for files that ARE in the data folder, asking you to point to them. If you did it would act like it couldn't see them...Why? I have no idea....all I know is once i moved EVERYTHING (all the files from the zip)up to the Desktop or a level below it like My docs, C drive etc it ran immediately and saw all files. You can run that SETUP and/or use add printer from control panel > printers and faxes
Oct 10, 2008 | Alps MD 5000 Thermal Printer
Micro Innovations IC150C Webcam Logo
175 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Joseph Hoffmann
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
