Question about Dometic RM2852 Refrigerator
Dometic refrigerator RM 2652 is not working
Just bought a 2005 Alpenlite travel trailer and everything was set up yesterday. It looked like the refrigerator was starting to get cold.
But when I returned tonight it was not cold and there was no lights on when I pushed the on off button or the check gas button. I have been connected to power here at the RV place
Could the refrigerator turn it self off some how? Can it still be working if the lights are not on?
So what I did was turn off and on ther breaker for the refrigerator.
This is my first night in the trailer and I have lots of perishables that need to bee cold.
  • Dometic Master
  • 6,674 Answers
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
Posted on May 09, 2010
  • Mike Butler
    Mike Butler May 09, 2010
    PS. If you've checked all other fuses in trailer, and have found that you do have 12 VDC going to the bottom of the fridge, you may have to remove the cover on the circuit board at back as well, and check that there isn't a blown glass fuse in there as well. Careful, you may have 110VAC (Hydro) fuse as well as 12VDC fuse in there. The fridge plug-in should be right in that area as well, so unplug it temporarily while checking fuses in circuit board.
  • mexifin Aug 25, 2010
    good job
Question: I have a trailer camper it has a Dometic Rm 2652 Ameri. refrig.
If I remember right on those, the system works off 12 volt--120 volt-- or propane (LP gas). have you tried one of the other power source to run it off of?? If you get the same type cooling results the problem is probably a small leak in the freon system. Those use special internal gas. When I worked for GE the only way to fix them was to replace the complete cooling system which came pre-charged with the special internal gas. Quite expensive after the warranty. Now if you switch power source and one of the other sources make it work the problem will be with the type power you were using when it failed to cool properly. Many people that had system problems with those camper type refrigerators removed them and installed a small regular dorm style refrigerator that could only be run off a 120 volt power system. You would need a 12 volt to 120 converter to run it while on the road if thats what you want to do.
May 01, 2015 | Dometic Refrigerators
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Apr 04, 2010 | Dometic RM2652 Refrigerator
Dometic R/M 2652 stopped working...burning smell and smoke
First of all any signs of burning on a circuit board means that a component has burnout in which case replacement will be required. Secondly depending on the colour of the stain , if its a dark colour the systems heaters are cooked in which case the cork insulation has melted the tare off and thats what you see on the floor. if its clear and oil based , the container has rusted and formed a leak ,in any of these scenarios its time to get a new one
Apr 27, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2852 Refrigerator Logo
1,638 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
