Cutting plotter jt720 driver This a update on a problem, manufacturer.. [ROHS 720]Shanghai Jintian driver.. JT-720 It came with Artcut software Running Win 7,, tryed win xp but nothing, With win 7 i can get it to work but it bugs out after 25% sometimes 50% and trys to go to far to the left, so far the belt jumps and i have to push the reset to stop it.. if it have it cut the name "MATT" it cuts "MA" then bugs out
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
What is AppHangXProcB1 in my cutter plotter
What kind of plotter. Reading the error it appears that some process is freezing up. This can be caused by a corrupt print job, bad driver. First step you want to take is to update the firmware on the plotter.
Jul 23, 2016 | Office Equipment & Supplies
SUDA SD720 CUTTING PLOTTER DRIVER
Dec 04, 2010 | Office Equipment & Supplies
I have a cutting plotter,, its a ShanghaiJintiar JT720.. works with Artcut6, <--this is what came with it. I want to use corelDraw with this plotter.. looking to make lettering with background...
basically you set corel draw to the paper size (vinly) your using.. click outside the page and set it using the selector on the tool bar..
once thats done,, click print,, select your plotter,, set your properties your using if not leave at default,, hit print..
Jul 12, 2010 | Sport & Outdoor - Others
I have a Windows Vista 32bit machine ive installed autocad2008 but i plotter wont plot
IS the driver for the plotter installed? Can you plot using any other program? Is there a test feature in the plotter driver so you can test the plotter? What plotter is it?
Nov 14, 2008 | Computers & Internet
Vista driver for rabbit 1360 plotter
You need to download latest driver for Vista. Here is the link that you can choose your product and download driver for Vista
http://www.m-audio.com/index.php?do=support&tab=driver
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 11, 2008 | Microsoft Windows Vista Ultimate Edition
319 people viewed this question
jasbo
jasbo
