Question about RCA F27442 27" TV
Bought a universal remote and input button does not work
How can i get dvd to work without the input button?
  • RCA Master
  • 1,213 Answers
You will have to find an RCA universal remote. Please search your local discount store and find an RCA remote with input. This is what you'll have to do...sorry!
Posted on May 08, 2010
Tv input stuck on dvd
Most TVs have manual buttons somewhere on the set to control volume up and down, channels up and down, and usually a menu button to access the settings. I'm not familiar with Insignia TVs but do a google search for your brand and model. If you don't have your original manual you should be able to find one online that shows where the manual control buttons are located and how to change the settings manually without a remote.
Oct 24, 2017 | Televison & Video
How to play dvd
If you are using the built-in DVD tray, press TV (in case you have a Cable Set-top box). Then press Input and navigate with the up/down keys to the line labeled DVD. Then press OK. Finally press play on the Polaroid TDA-03211C remote or on the side of the TV. The remote play button is in the center of the row below the row with skip reverse and skip forward buttons.
If you are using a different DVD player, press the input button and then the up/down arrows to get to the input for your DVD player. Then press the DVD button to control the DVD player.
If you are using a universal remote control, then you may need to program it to the TV and the DVD player separately. (Some universal remotes may only support the TV functions of this TV.) Make sure that your universal remote has an input button that works. You may need to try multiple codes for Polaroid TVs.
I hope this helps.
(note: the DVD must be correctly installed so that the printed side (label) is facing the front of the TV. If you do not get a response, try the disc in another DVD player. The DVD player laser tracking can fail without warning. If the disc plays in other units, this may be the problem.)
Mar 02, 2013 | Polaroid TDA-03211C 32 in. LCD HDTV
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
Sep 24, 2011 | Panasonic DMR-E55 DVD Recorder
Philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Apr 05, 2009 | Coby DVD-224 DVD Player
Game Mode
I have the Xbox 360 remote... It works! ^_^ its $19.99 at best buy. When you programming it just hold down the TV and ok button. The number lights are going to stay on... put in 0445 the push the channel button up and down the TV will turn turn off/on. Then push the input button and you’re done. Hope this help.
Aug 29, 2007 | Symphonic ST419E TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
The input button
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
Jul 11, 2007 | JVC AV-27F702 27" TV
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
RCA F27442 27" TV Logo
269 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
