Question about EuroTech EWF172 Front Load Washer
When I load the machine and it runs the cycle the clothes are still dirty and sopping wet at the end of the cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve the issue you’ll need to check so many things like the filter might be clogged, exit spigot might be clogged if the filter is clean, clogging of the path between the tub and the pressure sensor which senses the water level in the tub. Clogging can result in water level being incorrectly detected (may read as too high or too low) for the stage of programme that is executing, which can result in a halt of the programme. Please also check if some small clothing got stuck between the tanks, bad transmission, bad thrust bearing or brake hanging. If still the issue persists, then there should be air for passage in the standpipe on the back of the washer. Please check that the hose should be fitted airtight into the standpipe. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on May 08, 2010
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
May 17, 2011 | Electrolux EW1000i Front Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
The machine washes fine, but adds water on the drying cycle
The machine sounds faulty. You can bypass this by turning off the tap and respinning the clothes until the machine is fixed properly,
Oct 19, 2009 | Washing Machines
I have a Samsung front loading washer and we have made sure that it is level. The washing machine runs across the floor and the detergent drawer even flies open. At the end of the cycle the clothes are...
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 14, 2009 | Washing Machines
At end of cycle clothes are sopping wet
transmission clutch not shifing to high speed-mike
Jul 25, 2009 | Kenmore 23822 Top Load Washer
Wash cycle stops with 1 min left and clothes are sopping wet
dl mean door lock system fail. may be lose connection on your door lock or control board.
May 23, 2009 | Washing Machines
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
EuroTech EWF172 Front Load Washer Logo
Top EuroTech Washing Machines Experts
shaun taylor
richie46
Are you an EuroTech Washing Machine Expert? Answer questions, earn points and help others
