Question about GE Advantium SCA2000B Microwave Oven
While in use my microwave shut off and stopped working. Could it be a fuse? If it is a fuse where would it be located.
    Brigadier General:
  • 4,090 Answers
Mwaves shut off when they overheat and take a time to recover. This is a failsafe to prevent fire.make sure the unit has plenty of airflow around it and the vents are not blocked off ( hutches are notorious for overheating Mwaves) Sometimes the steam from a potato or a cup of water will overheat the sensor and cause it to shut down.
If it is a fuse the whole outer case hasd to be removed and it's usua;;y top left or right on the inner pod.
please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
Microwave shut off completely
Microwaves have an inline fuse inside that fatigues over time.Take the cover off,follow the power cord after it enters the housing to locate the fuse.
Mar 14, 2012 | Amana MVH220W Microwave Oven
My microwave just stopped working. No problems until now. In the middle of cooking it just stopped. No display, no beeps, no bouttons working, no light inside. There is power to the outlet I can plug in...
for the microwave to stop suddenly it has blown its internal fuse this is located under the top panel of the unit it should be white with two silver tips ( ceramic fuse) in some cases the fuse will blow for no good reason on the other hand it can be a serious fault the fastest way to check this is to replace the fuse and re test the unit if the fuse blows instantly then bin the microwave if not it the fuse may have simply failed
best of luck always remember unplug the unit first and always replace with same size and and current fuse
please rank this advice if it helped you
Dec 28, 2010 | Kenmore 80402 Microwave Oven
Stopped working
The problem you are describing is most likely a fuse that has blown. The fuse is in a holder just behind the control panel. It should have a rating on the fuse itself, typically it is a 15 amp ceramic fuse that you should be able to find at Radio Shack. But be sure to check the fuse for the right rating.
May 01, 2010 | Panasonic NN-S542 Microwave Oven
My microwave stopped working. PLEASE HELP.
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 19, 2010 | Frigidaire PLMV169DC Microwave Oven
Microwave stopped working, no power. Checked
There are two thermal fuses.
One is located on the magnetron and another one is located on top of the left side of the cavity under the air duct. The microwave has to be removed from the cabinet to access the second one.
The problem turned out to be a 20 amp fuse that I was able to replace and the unit is working fine. Sometimes a blind squirrel finds nuts.
Aug 24, 2009 | Kenmore Microwave Ovens
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
In this one, the most likely causes are the inverter or magnetron, but it really will need an experienced troubleshooter. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You should be able to locate a Panasonic-authorized servicer here: http://www.pasc.panasonic.com/WhereTo/FindServicer.asp?Pass=1 I would mention the exact symptom when you call so the technician can bring a new inverter with him when he comes out to repair it. Might save you having it pulled into the shop.
Sep 13, 2007 | Panasonic NN-T990SA Microwave Oven
GE Advantium SCA2000B Microwave Oven Logo
201 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
