Question about RCA HD52W59 HDTV Projection Television
TROUBLESHOOTING AUTO CONVERGE
WHAT DO I DO WHEN THE LITTLE AUTO CONVERGE ICON IN SETUP UNDER THE MENU IS NO LONGER AVAILABLE. IT SOMEHOW DELETED ITSSELF OFF NOW I CANT CONVERGE MY TV ANYMORE
  • 1030 Answers
SOURCE: RCA R52WH77 convergence missing from menu
THis is very common on these sets. there is a special fuse thats cause this.. kinda hard to get rca part number 259213.. .4 amp. the reason this blows is there is bad solder connections on the flyback. so when you replace this fuse you have to resolder these connections. so if you know how to solder and can find this special fuse. it is a fast and easy repair
Posted on Apr 09, 2008
  • 1030 Answers
SOURCE: RCA picture not aligned and cant find in menu
iwould guess you might have the fl231 fuse problem check und tips and trick section in my profile and read the article
Posted on Jun 19, 2009
ladywinn
  • 5138 Answers
SOURCE: I HAVE A RCA SCENIUM HD52W69DYX33 ONLY PROBLEM
You have a open FUSE fl231 it will be located on right side of FBT flyback transfomer there is 3 in a roll --small brown rectrangler looking caps it will be the one in the middle fuse they like like capacitors but are fuses.Let me know if this helps.also with TV off press and hold at same time vol- ch- on front of tv untill it comes on then release buttons.
Posted on Jul 24, 2009
Slinteriors
  • 8617 Answers
SOURCE: the auto convergence setting is not in the setup
the ITC222 convergence option missing repair kit under RCA repair kits will fix that issue. The kit contains the parts and detailed instructions. heres where to get the kit.
http://www.tvrepairworld.com/
Posted on Aug 02, 2009
Ecollier2012
  • 3459 Answers
SOURCE: RCA 52 INCH CONVERGENCE PROBLEM HELP/already replaced the fl231 fuse
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
How do you fix the convergence on a 2003 42 inch big screen tv?
In the menu on the tv setup you should find a test pattern that can be displayed for converging. In that menu there may be an auto converge which is much easier. If not, with the patter up you will have to manually converge the individual guns in the tv with the back off. There are adjustment knobs or screws for focusing the guns.
Oct 05, 2012 | JVC AV-48WP74 48" Rear Projection...
Double vision, believe one of the guns went bad
If the auto convergence feature is still listted under the setup menu then you need a convergence power supply board. If the auto convergence feature is no longer listed under the setup menu then you just need a repair kit. You can get either one from www.tvrepairworld.com
Sep 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Have a 56" RCA that i had the user manual for and lost it. i used to do the manual and auto converge. its been so long i forgot how to access it. help?
press menu then scroll to setup the auto convergence features are listed there. If they have disappeared you will need the ITC222A convergence option missing repair kit available from www.tvrepairworld.com
Mar 17, 2010 | RCA R52WM24 52" HDTV Projection Television
I have somehow deleted the icon for settings on my phone and do not know how to restore it
don't worry
i will tell u how to handle the situation.
goto help icon on main screen
select menu->applications menu->scroll down,touch settings->from top of page select open settings->
you are into settings menu
select phone->phone mgmt->factory settings
restore your original settings.
YOUR PROBLEM IS SOLVED
Mar 15, 2010 | Nokia 5800 XpressMusic Smartphone
I have a PT-47WX53 that has one vertical bar down the middle of the screen. Barely visible in a purple hue and about 3-4 inches wide. I'm looking for some suggestions. Thanks
A few simple things you may try. Under your menu on the tv look for convergence or it also may be under setup. Run the convergence setup and follow the on screen instructions. If the tv fails to converge while in setup you may need to replace some things however the parts are very very cheap. If your convergence setup works and you still have a bad picture, and or both, meaning the tv's convergence wont align then you may need 1 or 2 IC's and maybe need to change your coolant in the tv's RGB lens...all can be done with little experience and for under 50 bucks. I can give more detail if needed.
Dec 28, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I somehow delted the icon for my internet browser
Hi. To get your browser icon back, (probably it's been hidden) you only need to go to your main menu, press the menu button again, and you should see the "Show All" option, select it and now you'll see the hidden icons in grey color. When you come over the hidden icons and press menu button, you can select to hide or show them. And when you do the "Show All" steps again and select it again, this time you'll hide your icons selected as hidden. Hope this helps.
May 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
My 52' rca tv started showing red,blue, and green double picture and i cannot find the converge in the menu what can i do ..
if this is a rca itc222 chasis then you might have the fl231 problem. check out the ariticle under the tips and tricks section under my profile. the convergence menu is under setup in the convergence menu. if it missing then it may be the fl231. depending on what the model is.
Nov 26, 2008 | Televison & Video
Deleted text messaging icon
Have you tried doing a "show all" from the main menu to make sure it wasn't hidden?
Sep 20, 2008 | RIM BlackBerry Pearl 8100
Hello,i have just bought the D40 kit,and i,m very pleased with so far.the problem i have is trying to keep the menu screen on for longer.it only stays on for about 8 seconds.how do i get it to stay on...
If you haven't already done so, go to the Setup menu (the wrench). Under CSM/Setup Menu, select Full.
Now go to the Custom Settings menu (the pencil). Find Auto off Timers. Long will display image review for twenty seconds. Custom will let you set it for as long as ten minutes.
This is all under "Menu Guide" in the D40 manual.
Aug 02, 2008 | Nikon Cameras
RCA HD52W59 HDTV Projection Television Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
