Question about Legacy Audio ICE LA798 Car Audio Amplifier
No Sound No Power
Sorry i put the problem in the solution so just void that please> Here is the Problem- Ok i have checked every wire and i cant get my amp power lights to turn on ? Now the Blue LED on the top that says ICE will glow blue but the Red or the Green Light on the side which are the power LED will not come on at All I have a 2000 VW Jetta Any Ideas
  • 631 Answers
It sounds like part of the power switching circuit has failed. Your options would be to have it repaired/replaced or to try to repair it yourself. If you want to try to repair it yourself, visit the following link and then respond here. You will need to have the amp powered up and you'd need a multimeter to measure the voltage at several points on the board. A good quality photo of the circuit board would be helpful.
Basic Amp Repair
Posted on Mar 29, 2008
SOURCE:
I can't put my HP desktop back to factory setting Because i deleted the C: drive.
no computer stated
no OS stated, W10>???????????????
there are no permission on a void
sorry
why not post what it does.
turned on
inch by inch,what happens.
pretend helper is blind and cant watch you.
and please stop deleting things you dont understand.
or go broke fast.
doing real damage has consequences. $$$
you can in fact load fresh windows 10 for free
see that license on the bottom?
bingo, ask
so lacking the HP Disks you ask how to fix the hard way,.
there is away,
go to microsoft.com
go to down load MS operating system, ISO
pick what you had,
we dont know.
if w10 pick make and installe disc, for your
4gb USB stick memory or bigger
let it do that. takes, 1/2hour? if on fast internet
(using friends pc)
ok take new stick to dead pc
boot from STICK, (BIOS must have USB mem boot turned on0
ok you get say the w10 first install screeen
pick repair.
pick save my data.
like that,
its not free if no memory sticks.laying about.
not much in life is...
Feb 05, 2017 | HP Computers & Internet
Looking for a wiring diagram to fix an open in a wire going to my fuel evap valve at rear of truck. Engine code pointed me in that direction. I checked the valve manally and it is fine.
If you run a wire directly from the battery to the valve and it works, then you will know the valve is ok. That will mean you have a wiring problem or a power supply problem. I would imagine that the valve is operated via the ignition system somehow. You will need to trace the wire all the way to its supply. Sorry but I cant help with a diagram.
Sep 17, 2015 | Cars & Trucks
My suzuki savage ls400 has lost its spark ive replaced cdi and ignition coil still no go, also put a new battery in and checked connections including kill switch it turns over just cant generate spark so i...
Is it possible that the plug wire is grounding out?
Check it for any damage and listen for a "tick tick tick" sound when you are turning the engine over. That would be the spark grounding through the casing of the wire and not making it into the cylinder head.
Mar 11, 2014 | Suzuki Motorcycles
My screen in in dark negative and cant see whats on
Hello Mandy,
A dim screen or one that is black or suddenly blacks out, it might just be a power or battery issue. Do some troubleshooting. Check the power connection and see if its loose, then unplug it and take out the battery pack, then press the ON button for 20 seconds or so. Then put the battery back in. If that doesn`t work, you could have a burned out visual back light or a loose inverter. If the problem doesn`t go away, don`t open the LCD monitor and try to fix it yourself as that will void the warranty. Sorry for the late reply.
Thanks,Reymond
Nov 11, 2011 | Toshiba Computers & Internet
I need to find a new power button for my acer t690 . the old one craped out the spring and now cant use my desk top <sad and cryin> please help
Making a (DIY) Do It Yourself switch will cost you less rather than replacing it with the same switch, if you cant find one.
Tool's
Soldering Iron Soldering lead Desoldering tool (Optional) Shrinkable tube. Wires (Optional)
it might still work, most casing switches looks like this
Figure1: Power Switch with cable and female header pcsyke_33.jpg
1. Open your casing, trace the wires of your Power Switch. cut and replace the power button if found defective. some samples of PS buttons.. pcsyke_37.jpg
2. Solder the black and red wires to your new power switch. put the shrinkable tube, apply heat to shrink.
Hopefully this helps. Sorry I don't have actual images.
Thank you for posting.
Jul 07, 2011 | Acer Aspire T690 (AST690UP820A) PC...
Driver side power seat does not go back anymore. all other directions are ok
Could be one of the connectors under the seat thats dirty or a broken wire or the switch that faulty or even the motor. Start checking, cant help much more than that sorry.
Jan 09, 2011 | 2005 Kia Sedona
Hi!! i have a whirlpool duet front and she stop in the middle of the cycle and mark error f11 cant someone help me please and thank you
Hello there:
I am very sorry for the problem that you are having
Please follow the information that i have put together for you and hopefully it will help you troubleshoot this a little bit better ok?
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
May 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sound Card Problem
click on start go to control panel
click on sound and audio devices
make sure that the mute option does not have a check mark next to it
and put a check mark in the box which says place volume icon in taskbar
click on apply
then ok
then check if you get a volume icon and do check the sound
Jun 03, 2008 | Computers & Internet
Computer speakers
Are you sure your in the right slot with the speaker wire at the back of your PC it is the green imput. Make sure that the speakers are pluged in if there is a plug for them.
Sorry for sounding a bit basic I'm sure you have already checked these but sometimes people forget.
The volume may be turned off on the status bar at the bottom left of you destop. This is a small speaker double click it and check that the volume is not turned off.
there is no drivers ar anything for the actual speakers unless there is a problem with the sound card in your Dell.
Will you just check that all the wiring is correct and I will guide you through the trouble shooting to see is there anything wrong in the drivers if everthing is ok wiring wise.
Sean
Dec 11, 2007 | HP JBL Platinum Computer Speakers
Power on
you must use same cable used to power sound unit.
also check if the sound may have a remote connector.
Dec 04, 2007 | Jensen XA2150 Car Audio Amplifier
Legacy Audio ICE LA798 Car Audio Amplifier Logo
99 people viewed this question
Top Legacy Audio Car Audio & Video Experts
Dalynn Turner
Mark Skinner
Professor_V
Professor_V
Are you a Legacy Audio Car Audio and Video Expert? Answer questions, earn points and help others
