Question about Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2 OHMS => Model PV2000 Car Audio Amplifier
My peavey 5150 2 will power on but no sound....
My Peavey 5150 2 will power on but no sound.... four out of six of the pre amp tubes are lighting up and none of the power tubes are lighting up... all tubes are brand new too. What do i do??
  • Peavey Master
  • 5,603 Answers
It APPEARS that the preamp tube heaters are run from DC source while the latter ones and the power output tubes are run on AC.
Check the 6.3 volts AC going to the power amp tube.
That heater power is fed through fuse F2.
I suspect you will find that fuse has a bad fuseholder or is blown. A failure in the transformer is possible and I hope that is not the case.
A heater short in a tube is possible but doesn't happen often. Replace the fuse ONCE only and if it blows again investigate why. Could be bad wiring or a bad socket or an internal short within one of the unlit tubes. Thoose are rare but still possible.
Posted on May 08, 2010
Why wont the tubes in peavey amp not warm up
This is not user servicable. Here is a link to the service locator for peavey-
Peavey com
Jun 24, 2015 | Peavey Music
My peavey 5150 guitar amplifier turns on but does not put out sound. The light above the standby switch does not come on. I changed the fuse after it immediately powered off the first time. Now its just no...
Hi!
Unfortunatly, it's time to take it to the shop. Check the Peavey website for an authorized repair center in your area. An authorized repair shop will have better access to the parts and tech help from Peavey service.
No sense digging into the amp and getting a bad shock!
May 23, 2014 | Music
I have a Peavey amp but no sound is coming out?
Bad output transistors or bad Soldier joint in output section
Nov 26, 2013 | Peavey Xr 8600 8 Channel Powered Mixer
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
Hi, Peavey Classic Guitar amp , Has NO SOUND
Hi Mike,
If you switch on the amplifier, do you hear nothing at all?
Or do you hear low level noise or hum out of the speaker?
Don't know if you're technician.
If the tubes are glowing, you can measure the high voltage.
Check also fuse 3 and 4, thats the neg. voltage -27V and -14V.
regards,
Gerard
Jul 06, 2009 | Peavey Audio Players & Recorders
No sound - peavey bravo 112
I'm assuming that no sound applies to both the clean and ultra modes. You didn't say which tubes you replaced but I'm guessing the input tube was not replaced. Did you keep the old tubes? When "no sound comes out", do you hear any kind of a low level hum on the speaker output? I think the front end tube is open or the switch logic switch is defective. Hope this helps.
Nov 10, 2006 | Peavey (Solo) Microphone
Car Audio & Video Logo
513 people viewed this question
Top Peavey Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
Are you a Peavey Car Audio and Video Expert? Answer questions, earn points and help others
