Question about Maytag MER5770 Electric Kitchen Range
F9 error message - what does it mean and how can I fix?
It has to do with the locking device used to lock door when put into cleaning cycle. However, my door is open, and I can't close it because the locking device is in the way, and I can't move it back into place. I can slide it left and right, but will not stay on left side.
  • 5,911 Answers
If the heading you used is correct and this is a Maytag Kitchen Range, "F9" is a Door Latch Supervisory error, or a defective Electronic Range Control (ERC) board (this is the clock assembly board). Since you mentioned you are having difficulty with the door latch mechanism, I would attempt to repair or replace it first. The door latch costs around $50, while the ERC runs about $140-$150 @ repairclinic.com. Just type in your COMPLETE model number in the Search menu and there's a complete parts listing available with illustrations. They also have a service manual available (item# 893398) for about $30 that you can order to assist in repairs. Post back if you need further assistance, please. I hope this helps you.
Posted on Mar 27, 2008
  • Jeff Rockwell
    Jeff Rockwell Mar 27, 2008
    Thanks for Trying? You could have posted me comments if you needed further assistance. The fault code information was provided by Maytag. Is this a Maytag range? What have you tried to correct the problem?
Code F9-2 appears top door will open but bottom wont
Posted on Nov 09, 2008
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
What is Error message F9-5, bottom oven door is locked
Hello & Welcome to FixYa
Error F9-5 in your Maytage Gemini means Latch unlock lower and is displayed due to obstruction in door lock mechanism. If after cleaning the door lock mechanism the problem is still there then replacing the door lock mechanism is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 08, 2011 | Maytag MER6772 Gemini Electric Kitchen...
F9 error message during self cleaning cycle
Hello,F9 error means there is a problem with the lock switch.Check the wiring to the door lock switch (the wire harness may be connected wrongly).Check for stuck lock switch.
Thanks
May 31, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
I'm getting an F9 error, how do i reset it. I was trying to clean the oven and i mistakenly opened the door. It started beeping and gave me an F9 error
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$#%@#$%
Apr 29, 2010 | Frigidaire FEF352 Electric Kitchen Range
On a kenmore 790 electric oven what does F9 error code mean and how can I reset it I put it in cleaning mode and it won't open the door even after cooldown
Apr 13, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
There is a F9 error showing on my kenmore stove. What does this mean and how do I fix it?
Jan 07, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Oven door locked.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!$%!!!%!%
Oct 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FES367ABC oven gives f9 error, door lock light is blinking, door not locked. how do i fix
Oct 08, 2009 | Frigidaire FES367 Electric Kitchen Range
Door locks and F9 fault codes
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Self Cleaning problem
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question)(*&^%
Oct 21, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Maytag MER5770 Electric Kitchen Range Logo
395 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
