Question about Audiovox SIRPNP2 SIRIUS Radio Receiver
I have a Audiovox SIRPNP2 radio/SIRCK-1 that won't work reliably.
I have an Audiovox SIRPNP2 receiver that I purchased a lifetime subscription for about 8 years ago. The receiver still works but I can't get it to work reliably with the SIRCK-1 vehicle cradle. I still get the display which shows that I'm receiving signal and I can change channels but get no audio reliably. Sometimes I can get it to work by squeezing the cradle and receiver together but as soon as I let it go it quits. I do get a signal carrier on the frequency I choose but nothing else. Any suggestions??? Would another cradle cure the problem? I hate to put out more money on it but then I feel I'm missing out on the programing I've already paid for and can't use. I am a techie type so am not afraid to try anything, including taking it apart etc. Thanks for any help you can give me. Dennis
bluenadas
  • 203 Answers
SOURCE: No Display
Sounds to me like the display went bad on you. I'm not too sure your those though.
Posted on Jul 10, 2007
SOURCE: sirpnp2 reciever gets hot and loses signal.
I had the exact same problem with Sirius radios. I bought two Kenwood DTS-7000S receivers and both were sent back for warranty. Of the two, they only fixed one but by the time I figured out the other was bad, it was out of warranty. Kenwood, along with the repair community state they do fix such units, they toss them out. The thing that gets hot hot hot is the part that receives the Sirius antenna inside your unit. If you're like me and have nothing to lose then I recommend doing some cutting with a dremel and adding a small computer fan. It just takes a light breeze to keep that part cool enough (but it does take some sort of breeze, convection is out). For a home unit, find an old A/C power supply and match it to an old computer fan of equal or less voltage. For car, find a fan that uses 12 volts or less. It's an easy fix, really!
Posted on Dec 20, 2008
  • 10 Answers
SOURCE: how do i unlock or modify audiovox sirpnp2
call up Sirius and see if they have any manuals for that model to see if they can unlock it for ya or just have Sirius erase the reciever and start fresh by them reseting Hope this helps
Cheers
Johnthetr870
Posted on May 15, 2009
smarthome2
  • 1114 Answers
SOURCE: I have good antenna strength but no programming.
The tuner is bad. The antenna miniport on your tuner has either a broken or cold solder joint and therefore will not receive. If it's under warranty, they will replace it, if not, you can buy the tuner re-built on Ebay for around 50.00 and is better than new. Hope this helps
Posted on Jun 26, 2009
SOURCE: Audiovox SIRPNP2 SIRIUS Radio Receiver
Check your copper pin cylinder on the back of the receiver that goes into the cradle. The metal cylinder surrounding the copper pin can shave off or crack, causing these problems. If you can put your hands on another unit, you can replace this area with the parts unit. Unscrew the two screws holding the unit together and then slowly pry the unit apart, inserting a very thin blade and moving it slowly around the frame. Once inside, you will see screws holding down the area with the copper pins. You can remove this and put it in your receiver.
Posted on Aug 18, 2009
Will a garmin gtm 20 charger work with a garmin nuvi 660 gps
Yes! The GTM-20 is a charger with a built-in traffic receiver. The charger plugs into the cradle for the Nuvi 660 and then the Nuvi 660 snaps into the cradle.
However to receive traffic with the GTM-20, you will need to purchase a subscription, either yearly or lifetime. The traffic receiver receives traffic information from FM radio broadcast stations, which broadcast traffic data.
Feb 23, 2014 | Garmin GPS
How do I get free maps for my Garmin nuvi 1490t?
The only way you can get free maps is if your unit is a 1490LMT which is Lifetime Maps and Traffic. You would need to register your unit at www.garmin.com. You do have lifetime traffic because you say your unit is a 1490T.
If you don't have a lifetime map subscription, you will have to buy a lifetime map subscription or purchase new maps when they are released. The lifetime map subscription will save you money in the long run.
Apr 12, 2013 | Garmin nuvi 1490T GPS Receiver
I have a lifetime subscription on my PNP3 and I think it's on it's last leg. What are my options to transfer the sub to another radio? thanks Hank
It depends when you bought the lifetime subscription. The rules changed. Post and follow this link. It seems to cover your question:
https://listenercare.siriusxm.com/app/answers/detail/a_id/4555
Jul 25, 2011 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
How is my 205 updated? what do I need to do and how much does it cost ?
Updates come at a cost, 54.95 to get the most current map set or 89.95 for a lifetime subscription to map updates. The lifetime subscription is the more economic way to go saving 20$ by the second year. You are eligible for a free update within 60 days of the units purchase, so you could try obtaining that before paying. All your GPS updates & accessories can be obtained at www.gpscity.ca or www.gpscity.com.
Hope this helps!
Apr 07, 2011 | Garmin nuvi 205W GPS Receiver
How do i unlock or modify audiovox sirpnp2
Cheers
Johnthetr870
May 15, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
I inherited a disfunctional SIRPNP2. The signal strength meter in the lower left corner always displays an "x". Anyone have an idea? Thanks
A couple of things to try. First, try pulling out the anntenna from the back just slightly. My SIRPNP2 gets a better connection that way. Also, check to make sure that your annenna isn't bad. If you have a friend that has Sirius, connect their anntenna to your unit. If it works, replace your anntenna.
Apr 24, 2009 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Sirpnp2 reciever gets hot and loses signal.
Nov 04, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Aug 15, 2008 | Audiovox SIRPNP2 SIRIUS Radio Receiver
X act sirius streamjockey
any trees or build in the way no signal
Dec 16, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Antenna not detected
Call Audiovox support. After waiting an hour I was told the unit (pnp2) was faulty and I was to call customer service to arrange a replacement. Mine is on the way to NY.
Jan 15, 2007 | Audiovox SIRPNP2 SIRIUS Radio Receiver
Audiovox SIRPNP2 SIRIUS Radio Receiver Logo
111 people viewed this question
Top Audiovox Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Chinmay Joshi
Chinmay Joshi
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
