Question about Brother MFC 210C All-In-One InkJet Printer
Keeps showing unable to clean . Tried everything .doesn't work.
  • 4,041 Answers
Hi there
You say you have tried everything, so I not know if you have tried this.
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 08, 2010
Working on a 2005 Buick LaCrosse cxs with the 3.6l. Car won’t start. Won’t turn over or anything. Hooked tech 2 to it and it says fuel security disabled. Have master key. Tried reprogramming but it doesnt...
First make sure the battery is fully charged. Then check for clean battery post connections. Then check all the main fuses located in the plastic box under the hood close to the battery on top of the inner fender. You should have all dash lights if everything check out to this point and it should turn over with the key.
Aug 25, 2017 | Buick Cars & Trucks
My 82 XJ650 won't start after cleaning the carbs.
try taking the carb off and let it set in sea foam for a night
Jul 19, 2013 | Motorcycles
I can't get out of my recovery mode on my Archos
Is the button sticking or is it damaged
Feb 01, 2013 | Computers & Internet
My lexmark s605 doesn't work, but the pinter and copier are all fine
Plug in usb cable from printer directly to computer then print something. If you're successful, try to print something. If you're on wireless connection, disconnect the usb cord and try to scan.
Aug 27, 2012 | Lexmark "interact s605 wireless all-in-one...
Dometic rm2652. Inside of fresh food section is down to 20 degrees, everything froze
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Since this unit has no compressor and uses an ammonia mix and heat to cool, it isn't your standard household refrigerator. So be careful working around the coils.
The most common failure for your problem description is the thermoster followed closely by the lower control board. But we have also been finding more and more corrosion buildup on the terminals that is keeping the unit from functioning correctly. Suggest you ohm check the thermoster to see if it has opened. If that shows an open, then replace. If that doesn't work, then take the lower control board out and clean the terminals and connectors with a scouring pad following by the #2 pencil eraser cleaning of connectors. If that doesn't correct it, then replace the lower control board.
Sep 11, 2011 | Dometic RM2652 Refrigerator
When people call me, their name or number doesn't show. I have tried everything. How do I fix this?????
Check the memory status if what memory-in-use preferred, might select both in-use memory,might double the save contacts that's why unable to recognized which contact to be in-use.choose either sim memory or phone memory and double check your contacts if there's a duplicate.
Jul 21, 2011 | Nokia E63 Cell Phone
My blackberry 8520 keeps on saying my memory card has fatal errors and when I go on the computer the folder 'blackberry' doesn't show. My phone wont let me format or repair the card. I've...
Look on this forum:
http://supportforums.blackberry.com/t5/BlackBerry-Curve/Problem-updating-device-software-quot-Fatal-error-quot/td-p/82515
Jun 18, 2011 | SanDisk 2GB microSD Memory Card
Unable to clean wold not go away
Here is a link to the brother site where it will show you the step by step procedure with illustrations for correcting the problem.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_000.html?reg=us&c=us&lang=en&prod=mfc5840cn_all&Cat=11
Hope this helps.
Aug 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
Unable to clean
Hi, I tried the solution above "by obiewan" it work's for me but I do a little changes on his pattern.
1. Unplug your printer
2. press down the menu/set then plug it (just keep oh pressing it down until you see the message error 46 show up on LCD)
3. press 80
4. then look for "Purge", i think its on the 25th when you scroll down
5. then reset the pruge count to "0" by pressing 2 7 8 3
6. then press stop/exit
7. then press 9 twice
VOILA!!!
Dec 10, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
360 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
