Question about ViewSonic VG800 18" LCD Monitor
Thanks I used your solution to repair 24 bad Viewsonic 19" flatscreens. We had 28 bad and 24 were due to the bad cap. The others come on for like 1/10 second then turn off. Problem follows the LCD panel not inverter or power board.
  • frank_drebin Mar 27, 2008
    No, what I mean is, I swapped a known good power/video board and the problem persisted. I then swapped the inverter board, same problem. The problem was in the LCD itself. I used the other boards (with the new caps) in other monitors with no problem.
    Yeah, these are my parts machines now. Thanks for your help though. Saved us a ton of money. I hope these last a few more years now. I also had 10 Samsung Syncmasters that wouldn't power up and fixed them as well. They each had 3 bad caps and a bad fusable link on the 13v power supply.
    Scholar:
  • 42 Answers
Without having it in front of me to test it's tough to tell. Sounds like a power supply problem, the shotgun approach would be to just replace all the electrolytics and see if that fixes the issue starting with the ones closest to the power input.
This is a VG800 right? Because the power supply and video boards are integrated on the monitor, so you can't really narrow it down between the power or video side of the board (you can unplug the inverter, but it sounds like you've already tried that). Since the power button is just a soft start button (the monitor always has power once it's been plugged in) you can try troubleshooting the parts of the board that are constantly energized and figure out where the power is switched on by the soft switch, that may be helpful.
Posted on Mar 27, 2008
  • Chris M
    Chris M Mar 27, 2008
    Ok, that makes more sense then, I was wondering what you meant.
    So the LVDS signal that is sent off of the main board is sent up to another circuit behind the screen itself. There must be an issue on that circuit. If you take the panel itself out of the cradle there should be a small metal panel that is screwed onto the back of the screen itself. If you remove the screws and carefully flip the metal guard forward you should see the circuit that actually sends the signals to the individual transistors on the screen itself. I'm wondering if something isn't shorted to the panel chassis up there and causing the panel to shut off. The trouble there is that the circuitry on the back of the panel is all very tiny surface mount components which are very difficult to work on so unless it's something obvious. I don't really have any more ideas :) You might want to keep those four as backups since you have so many of those monitors around if you can't come up with anything.
SOURCE:
Our ViewSonic VA1912WB purchased from Officeworks, Osborne Park Western Australia on 12 November 2007 worked perfectly until 28 December 2010. I presume it is now out of Warranty. While in use, the screen...
Common problems are due to bad caps (leaking/bulging top/bottom seal). Inspect that first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Please post back what you find.
Jan 07, 2011 | ViewSonic VA1912w 19" LCD Monitor
What does it mean when the ViewSonic VG900b light turns from green to yellow?
It can mean it is not getting the video signal from the video card, bad VGA cable, or it is in safety shutdown mode. Try it with another PC first. If it still does not work then you will need to troubelshoot it. Read my guides and see the picturesd of failed VIEWSONIC and all other brands mostly due to bad caps.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 25, 2010 | ViewSonic VG900b 19" LCD Monitor
No display - green power light blinking
Common problem for monitors are failed capacitors in the power supply, that will be the first place to look. See pictures of failed VIEWSONIC and other monitors due to bad caps and other causes:
Please post back what you find so we can guide you further and will also help other people with the same problem.
Apr 05, 2010 | ViewSonic VP920b 19" LCD Monitor
Half way through pc posting screen goes blank Viewsonic VA1912W LCD Monitor
Common failures in this monitor is the 470uF caps in the inverter section (close to the inverter transformers), but you should replace all the caps in the 5vdc and the 12vdc as a whole set. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 26, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
My viewsonic monitor goes into sleep mode and it doesn't want to wake up. Eventually it works when i pull the plug and reconnect, or reboot but it is getting worse.
It may be getting worst because the capacitors in the power supply are going bad, look for caps with bulgign tops or seals, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 21, 2010 | ViewSonic VA1912WB 19" WideScreen Monitor
I have a viewsonic va902b screen when I turn it on the picture flashes and wont stay on the screen, how do I fix it?
More likely to have bad caps in the power supply, that is the first place to check for bad caps with bulging top, it can also be bad inverter circuits, or bad lamps, open it up and post back what you see so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA902b 19" Monitor
Turning the screen on and off a few times stops it flashing
This monitor is released in 2004, due time to check for bad caps with bulging top, post back what you see inside so we can guide you further, see example of failed VIEWSONIC monitors because of bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 18, 2010 | ViewSonic VX910 19" LCD Monitor
It's a Viewsonic VX715 Monitor. When it's turned ON, It goes black in 3 seconds.
It can be one of thses: bad caps (bulging top or bottom seal) in the power supply, bad backlight inverter circuits, bad lamps. You need to open it up and lool for bad caps first, then measure the voltages across the filter caps, you should have 5vdc and 12~18vdc (there are two power supplies: 5vdc for logic, 12~18vdc for backlights citcuits) Post back what you find so we can guide you further, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | ViewSonic VX910 19" LCD Monitor
Monitor turns black after 2 seconds, Viewsonic VX910
Check the power supply first for bad caps, then check to see if you do have 12vdc feeding the the inverter circuits, worst case will be the lamps, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | ViewSonic VX910 19" LCD Monitor
Open Questions:
-\&;-WINDSTREAM Customer Support Phone Number #{+ I:8OO-828-O294 }.U.S.A This windstream USA phone number is ranked #2 out of 2 because 7,728 windstream USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the windstream USA Customer Support department for problems like Where to buy, Complaint, Customer support, Repairs, Returns. As far as we can tell, windstream USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. windstream USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact windstream USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling windstream USA Calling windstream USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from windstream USA Customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with windstream USA's Customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare windstream USA's phone numbers against each other. Contacting windstream USA in General While I8OO8280294 is windstream USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach windstream USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact windstream USA.
Oct 16, 2019 | Best Computers & Internet
See all ViewSonic VG800 18" LCD Monitor Questions
ViewSonic VG800 18" LCD Monitor Logo
127 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Ekse
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
