Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
I HAVE A SONY KDF-60XS955 I AHD SOME ISSUES WITH IT AND PAID A SONY TECH TOCOME OUT AND DIAGNOSE IT HE FIXED THE PROBLEM BUT ALSO NEEDED A NEW LAMP HIS WAS TO HIGH SO I BOUGHT MY OWN AND PUT IT IN AND I GET THE SOUND BUT NO PICTURE ONLY A BRIGHT COLOR SCREEN???
  • 2,335 Answers
I can help with your Sony KDF-60XS955.
I assume you found the correct part, UHP lamp, 132W XL-210.
I've uploaded the Service Manual for your TV, so you can run the diagnostics yourself and review the installation steps to make sure nothing was missed.
I hope that helps.
_____________________________________________
Sony KDF-60XS955 Manual Download
Sony KDF-60XS955 Service Manual Download
Posted on May 08, 2010
The picture goes off, the power/standby light
Sony KDF-60XS955 picture goes and power/standby light light flashes
Most likely you have bulb failure. First step in troubleshooting is "Change the Lamp or Bulb". Lightning, power line bumps and collisions with vacuum cleaners can all shorten lamp life. Rough handling in shipment can also happen without your knowledge.
+90% of all Sony LCD Rear Projector "No Picture or Intermittent Picture" faults are related to bulb failure.
If new lamp does not improve the situation, then hands-on troubleshooting by someone that has parts and knows how the unit works is the only practical remedy.
easyab
Mar 14, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
How do I replace the Lamp
Question shows it is Sony KDF-60XS955 TV
Please lose thumb screws at lower corners of TV and pull out lower front panel, you will find lamp cover, unscrew and take it off, lamp is in fornt of you, lose its screw and pull it out.
Insert new lamp and put things in reverse order.
Lamp replacement procedure is also written in user manual of TV.
Click Sony Support to download user manual copy, if required.
Thanks.
Oct 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Picture is dark even after ajustments
Is it Sony KDF-60XS955 TV and have you replaced its lamp?
Symptom shows TV needs new lamp.
Let me know if lamp is replaced or not to provide you more info.
Aug 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Thermal fuse on sony KDF-60XS955
check out link below for part. i have 55cs955 and just ordered one. I still do not know where to find in TV but as most post says its somewhere near lamp housing.
http://www.partstore.com/Part/Sony/Sony/191002393/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=KDF55XS955
Apr 01, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Please help-question about sony optical blocks
Talk to Sony about the blue blob issue, they may still replace the optical block for free.
If not, fix the blinking light TV.
Blink Codes
3X - Lamp cover not installed correctly, usually after lamp change, or cover detect switch is bad.
4X - Check fans (one or more failed to pass RPM test during power on diagnostics)
5X - Lamp ballast (power supply)
6X - Usually the thermal fuse - usually from inadequate air flow (fans dusty)
All other codes usually require a trained technician to diagnose and repair.
Oct 29, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60 in. Rear Projection popped and turned off
the reason your lamp blew so quickly is the the lamp fan has become cloged with dust. this is a known problem by sony and I have done 15 or so of the up grades needed. first look at the lamp door is it discolored and warped. if so have a tech order the up grade kit which includes a new door, siraco fan, thermal fuse, and lamp. the return fan may also be needed. also some service menu changes need to be made with the fan voltages of fan 1 and fan2.
Feb 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-60XS955 Replaced Lamp. Slight discolor
Dont know if this is the same problem your having or not.
2003-2004 Model Year Grand WEGA Televisions:
Models: KF-42WE610, KF-50WE610, KF-60WE610, KDF-70XBR950, KDF-60XBR950, KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620.
As technology evolves, Sony continually looks to stand behind the reliability of its televisions. It has come to our attention that a very limited number of televisions manufactured between 2003-2005, after a period of time exhibit a stationary scribble / random line pattern on the screen. Click here to see photos of this symptom.
As part of our commitment to quality, Sony is announcing that for any owner of this model television who paid out-of pocket expenses on or before May 26, 2006 for an estimate or repair service to replace the optical block for this specific issue, Sony will reimburse the customer by mail for his/her parts and labor expenses. To receive reimbursement, please follow completely the directions and terms on the claim form for reimbursement; all claims must be postmarked by May 31, 2007.
In addition, for any customer who later experiences this issue on one of the affected models, Sony will cover the cost of the optical block repair at no charge through September 30, 2007. All other terms of the Sony limited warranty continue to apply.
Jan 23, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY 60" KDF-60XS955 power goes off and on every 30 sec I have the same 30 sec on/off problem with a Sony KDF-E60A20 60 in. HDTV LCD Television.  However, the actual power does not go off completely, just...
its the bulb i have the same problem with that model the service tech said life spann on bulb is 2years he replaced it fixed you have to readjust all the pic settings because new bulb make pic too bright
Dec 27, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony kdf-60xs955, rear projection tv
There is a Thermal fuse under the lamp housing that opens up and Sony has a New style fuse to replace it with, it opens up one of the p/s lines to set code 6, replace with new thermal fuse and test. You will want a Skilled Professional to replace this fuse as it does require some dissassembly and removal of light engine to remove fuse from under lamp housing to put new one on side of lamp housing.
Jun 19, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
209 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
