Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer SUD F-02 problem: Recently I noticed that the water was not draining inside the washer once in a while. Starting last week, I heard the beep sound and it told me it is F-02. After investigation, it was running the last cycle with SUD error and then F-02 afterward. I cleaned the drain filter (white) and opened up the impeller to make sure there is nothing blocking it. I assume that there is nothing inside the hoses. Anyway, I was able to run one load successfully (with less detergent). I ran the 2nd load but the F-02 error came back. I unplugged the washer for 2 minutes one time without success. I unplugged the washer for 2 hours without success. I left the washer for 6 hours, and can run the drain/spin cycle and finished the cycle. It leads me to believe the pump might be overheated or the something has to be reset? I called in a service guy and he cannot locate the problem and told me that the real possibility is the control unit which is very expensive! Now what I have to do is wash only one load everyday. What do you think the real cause?
  • 15,935 Answers
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
Whirlpool duet washergets a code 2 when it gets to spin cycle.wont rinse and spin
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed.
1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Apr 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet HT washer. I keep getting the F 02 code and SUD right after. I have cleaned the filter and drain hose. It didn't fix it. I replaced the pump this afternoon. That didn't fix it. I...
Hi there I have found the code for you and hope this helps?
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya
Feb 12, 2010 | Washing Machines
Have error code of f 02 showing up on my duet. It is not finishing spin or drain cycle?
display.
or kinked.
Nov 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Have error code f 02 showing up on my Duet fronload washer, during rinse and spin cycle
F/02
DURéE EXCESSIVE DE LA VIDANGE
display.
Si la durée de l’opération de vidange est de plus de huit minutes, le système commande
la fermeture des électrovannes et l’affichage du code “F/02” clignotant. Appuyer deux
fois sur la touche PAUSE/CANCEL pour commander l’effacement.
NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus
tard le code “F/02” sera affiché.
or kinked.
My washer show error(f-02
F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9150PW will not drain.
Needs new drain pump. About $140. Will fix F02 / SUD error. Basically the drain pumpm isn't pumping water out. about 5 minutes to replace.
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will rotate to balance
To solve this:
thanks.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer will not go through a complete cycle. It flashes F2 and will sit on SUD for ever as well as run on the last 1 minute for an hour. Help
If the drain time exceeds eight minutes, the water valves are turned off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the display. NOTE: After four minutes the “Sud” error will be displayed, then four minutes later the “F/02” error code will be displayed. Si la durée de l’opération de vidange est de plus de huit minutes, le système commande la fermeture des électrovannes et l’affichage du code “F/02” clignote. Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement. NOTE : Après quatre minutes le code d’erreur “Sud” sera affiché; quatre minutes plus tard le code “F/02” sera affiché. Possible Causes / Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
02 f error code
F/02 code appears because :---------Long DrainIf the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
to resolve this problem  :----------
  • If the above does not correct the problem, replace the pump.----------------
  • rate the solution.
thanks.
Jan 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
100 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
