Question about Nikon COOLPIX Cameras
Nikon coolpix 3100 - maximum card support?
Nikon coolpix 3100 - what is the maximum card memory it can support? It uses SD cmpact flash. I had problem with 2 GB card.
    Brigadier General:
  • 4,090 Answers
Yes you would. It can inly accept 1GB cards. Just as a tip large capacity cards make it slow to recover from a write after taking a pic so if you can get say 512K cards still use those they recover from writing a lot faster
please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp 720hd Video 15x...
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
May 04, 2012 | Nikon COOLPIX S52 Digital Camera
This card cannot be used Nikon coolpix 4300
Try formatting the CF memory card using the Nikon camera. Go to the Menu to format the CF card.
Apr 15, 2012 | Nikon COOLPIX Cameras
I have nikon coolpix s203. When i plug SD in unlocked position it shows "The card can not be used". When i plug SD card in locked position camera will see card but nothing writes io reads from...
You don't say whether this is a new card or one you used before. I'm going to assume this is a new card (otherwise, it means the card has become corrupted or there is a camera fault).
You say it is an SD card, but don't mention the capacity. "SD" cards larger than about 2GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
I expect your camera just won't work with this kind of card. It is often difficult to find out the maximum capacity memory card a camera will use, as today's cards are much larger that those available when the manual for the camera was written, but as a rule, if the memory size is larger than the largest size mentioned in the manual, you should expect trouble. You can always carry several smaller cards if you really need more space.
Dec 26, 2010 | Nikon Coolpix S203 Digital Camera
I want to know about different types of memory cards available for Nikon D3100
The D3100 takes SD and SDHC cards. Physically they're identical, but SD cards are limited to 2GB in size. SDHC cards range from 4GB to 32GB in size. They come in different speeds but if you're just taking snapshots the speed won't matter. If you shoot a lot of video, or shoot in RAW, then you might want to get class 4 or faster SDHC cards. Otherwise just stick to the major brands and go with price.
Nov 30, 2010 | Nikon COOLPIX Cameras
I Purchased a new SDHC card from Argos which was 4 GB as the one that came with my Nikon coolpix 3700 is a 16mb I put this new one into my camera and the camera showed that you couldn't use this card,...
Your camera will accept a maximum SD card capacity of 1GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 1GB capacity.
Please take a moment to rate my free answer.
Oct 06, 2010 | Nikon Coolpix 3700 Coolpix 4200 Coolpix...
Nikon coolpix 2100- out of memory- After installing 4gb CF card
4GB requires FAT32. Camera firmware only supports FAT16. 4GB won't work because FAT16 has a 2GB maximum size limitation. 1GB CF card is Nikon's "approved" maximum for this camera.
Catch: 22 1GB -and lesser capacity- CF cards are no longer manufacturered or generally available in 2010. When the current CF card dies, the still working camera also becomes throwaway unless you can source a CF card 1GB or under. 2GB may work, but with 'issues' per caution below.
CAUTION: Anecdotal evidence suggests the final release -& current- firmware for cameras of this generation is also encumbered by with a maximum picture number limitation of 999, realistic at the time of original manufacture when 256MB was a the largest capacity CF card but completely nonsensical now.
Summary: This is my first NIkon Digital camera and also my last.
Apart from the noteriety of the ubiquitous broken Nikon plastic battery latch, a major design flaw Nikon refuse to acknowledge or accept liability to rectify -since self-repaired better than OEM, Nikon policy on firmware support is complete abandonment of product within an unacceptably short service window. ie: a deliberate poilicy of enforced obsolescence.
Suggested Problem Remedy: Do buy a new camera supporting SD Cards of current capacities. Don't buy anything branded Nikon.
May 24, 2009 | Nikon Coolpix 2100 Digital Camera
Memory card removal
Here is the manual: DIGITAL CAMERA
Check page 10 in the manual.
Dec 26, 2008 | Nikon COOLPIX Cameras
Flash memory card
Perhaps it didn't complete formatting. This happened to my mom and I tried her card in my camera and it wouldn't work there either. We had to replace. You might take it back since you just bought it. That way, you will know if it's the card or the camera.
Dec 27, 2007 | Nikon Coolpix 3200 Digital Camera
Cameras Logo
323 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
