Question about Samsung CLP 300 Laser Printer
Printer just stopped printer.
I have changed all ink, turned off and on uninstalled and re-installed. It runs like it is going to print then the red light comes on. It never seems to grab the paper to print
    Sergeant:
  • 253 Answers
Use new cartridge
Posted on May 08, 2010
The RED light is per menantly on when the toner has run out. I fit a new "samsung "toner catridge but the red light stays on and the printer keeps asking for a new toner and will not operate
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 09, 2011 | Samsung ML-2851ND Laser Printer
I've changed my colour ink cartridge three times now and it still wont print red.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow the red color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 17, 2010 | HP DeskJet 3650 InkJet Printer
Can't print both red lights brinking
Hold down the power to shut off. It is possible the Ink level has come down. Before you shut down Look in the properrties of the priinter in the PC for the ink level status. If low use the maintenance key to hold down in changing the INK cartridges.
If not remove the printer and uninstall the printer software, the install back and connect the printer to be detected and installed.
Now the priner must work correctly.
Aug 29, 2010 | Epson Stylus C66 Inkjet Printer
Printer is no longer printing from the magenta cartridge. I have changed the cartridge and run the cleaning cycle 4 times and still not red. What else can I try?
Aug 22, 2010 | HP Photosmart C5180 All-In-One InkJet...
Red light stays on after i changed ink? will not print
the red light shows an error/alert
make sure when you installed the cartridges
they are properly snapped inside
also check if the printer printed a test page
as it is must once you put the new cartridges
youmay also try uninstalling the cartridgesand turn of the printer,perform a power flee
turn it back on and install it one by one .
Jul 09, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Unable to print on printer Dell 926 -test page prints ok
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
May 23, 2009 | Dell 926 All-In-One InkJet Printer
Problem printing with epson stylus office t30
Hi.
Please try to uninstall and re-install the drivers on your laptop now that the ink light is not on steady anymore.
As i see it, the issue is hardware. The printer will not allow you to print anything if any cartridge is not recognized or any cartridge is out of ink. The red indicator light on the printer that was on steady while your installing the drivers on your laptop, indicates that there was a cartridge that was out of ink.
May 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
PRINT command
uninstall ink with printer on and turn off then back on when printer says install ink do so if that doesnt work clean contacts with rubbing alcohl on ink cartriges.
Dec 08, 2007 | Dell 922 All-In-One InkJet Printer
Samsung CLP 300 Laser Printer Logo
142 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
