Question about Kenmore Washing Machines
Front load washer - loud banging noise and wont spin fast
I have a Kenmore front load washer. It sounds like there is a loose part or something inside the tumbler. With each ratation something is hitting something. You can mannual turn the tumbler and hear that somethign is loose. The washer still washes but will not spin fast. It starts to spin (you can hear the loose part still) then it stops and tries the other direction and never actually spins fast. Clothes end up clean but really wet.
  • jpclaw1 May 08, 2010
    I think you Number 2 possibility is the issue. When I stick my hand in and move the stainless steel interior there is lots of movement as if it is not attached to the tub. I can push it back and forth and up and down. If I spin it there is defintely a loud clunk. What does it mean that the bearing is bad? Is this a fixable problem? Is it part of the 10 year tu warranty? Or is it a new washer?
    Thanks,
    JC
    Solution was very helpful and appreciated.
    President:
  • 949 Answers
It sounds like it could be one of a couple things. It could be the pulley that attaches to the back shaft of the basket has come loose and is hitting on the tub, you would have to take the back off the machine and look at the pulley to tell.
The rear bearing in the tub has gone bad and the inner basket is rubbing on the outer tub. To find out reach inside and see if you can move the stainless steel tub up and down, if you hear a clunking when you do this or it has a lot of movement independent of the outer tub the bearing is bad
Something has broken off of the tub and is moving around inside between the tubs. No way to find out unless you take it all apart.
The second two are something that are very time consuming repairs.
Let me know if you have questions.
Posted on May 08, 2010
  • Philip May 08, 2010
    Hi J.C,
    It sure does sound like the rear bearing. On this model the bearing is part of the rear tub assembly, if the bearing is too warn it can damage the shaft on the basket also.
    It is a very time consuming repair, to take a guess I would say it would run about $600.00 parts and labor to repair.
    I am not familiar with the warranty, but I would check that first before buying a new one. If you end up not having warranty (as much as I like to repair things) I would have to recommend not putting the effort into this one.
Loud noise during spin cycle
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
Making loud banging noises. Sounds like something is inside, but nothing is. Something seems to be between the basin(?) and its casing.
It is very common for an item to get stuck between the basin and casing. You can drain the washer and spin the basin manually a few times in either direction. It should spin smoothly, but with some resistance. You may need to remove the front cover by typically lifting the top enough the loosen the front panel, then inspect the perimeter of the basin and the condition of the belt and motor. Remove anything that doesn't belong (i.e. a sock or zipper!)
Hope this helps! Rate my solution!
Jan 05, 2010 | Kenmore 44102 Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Loud sounding like loose parts when draining
possibly a coin or hair clip in the pump if not the propeller on the pump may be loose try locating the pump under the machine and try to romove it
Nov 11, 2008 | Kenmore 43052 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Washing Machines Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
