Question about Ram Pickup Alarm Remote Auto Start Install Cd
I have a 2001 dodge ram sport. i went to the store and when i got out of my truck and closed the door the alarm ingaded, so i got the remote from my house and it wont disngage the alarm. how do i turn it off?
    Problem Solver:
  • 7 Answers
There should be an override switch mounted up under the dash.. It willl either be a push button or a toggle switch.. If push button, with door open turn key on then off then push and hold the push button in for about 4 to 5 secs then the alarm should shut off nad the little led should goes solid. if toggle key on then off and the toggle the switch to the opposite side
Posted on May 13, 2010
  • evilsk8erboi Mar 26, 2011
    Ok will the autostart not let u start ur truck if alarm is engaged
How to reset security system for dodge caravan sport 2001 3.3
Step 1
Insert the ignition key into the driver side door lock.
Step 2
Turn the key counterclockwise to unlock the door.
Step 3
Turn the key clockwise to initiate the alarm activation sequence.
Step 4
Turn the key counterclockwise. The alarm will stop and reset itself.
Mar 09, 2016 | Dodge Cars & Trucks
Panic alarm does not work. Locksmith verified that it is not the remote fobs.
central timer module" - Dodge Dakota Forum
www.dodgedakota.net/boards/gen/21983.html
Jan 2, 2009 - 21 posts - ‎18 authors
I have a Dak 2000 3.9 Ltr V6, Single Cab, Bare Bones. ... Panic Mode .... ooops....i mean the remote entry and alarm system does NOT work ... i have a 2002 dakata where can i buy a ctm looked all over nobody sell them can thay be rebuilt ... I was out the door $550.00, and they washed the truck also.
Truck wont work/Key Fob won't work/wont start/wont do anything ...
www.ramforumz.com > ... > Electrical
Apr 10, 2010 - 10 posts
Truck wont work/Key Fob won't work/wont start/wont do anything! ... Maintenance & Repair > 3RD Generation Dodge Ram - 2002 to 2008 Dodge Ram Trucks > Electrical... Soon as I manually unlock the door, and open it.... the factory panic alarm starts going off. .... Vehicle: 2004 Dakota Club Cab 4X4.
alarm going off when opening the door.. embarrassing and annoying ...
www.cumminsforum.com > ... > 3rd Gen. Non-Powertrain
Jan 12, 2012 - 11 posts - ‎9 authors
how do I stop my trucks alarm from going off when I open the door? it did it ... to thetruck and opened driver door (it was unlocked) and the alarm started going off. ... I do not have a remote unlocking device (or it doesnt work) so I do all .... alarm will go off then I have to use the FOB panic button to shut it off.
Keyless entry/panic button/alarm - Dakota Durango Forum
www.dakota-durango.com > ... > Gen III Dakotas
Jan 10, 2016 | 2002 Dodge Dakota Club Cab
How to disconnect factory alarm on 2001 dodge ram 1500
The factory alarm or VTSS as Chrysler calls it, is integral to the CTM and PCM computers in the truck. The only way I know to remove it is by sending it to a service like SOS Diagnostics to have the 2 computers reprogrammed. http://sosdiagnostics.com/chrysler/ You could also buy used ECU's from a different truck without alarm, but you might run into VIN mismatch problems with your ABS.
Sep 17, 2012 | Ram Pickup Alarm Remote Auto Start...
I just bought a 2001 Subaru Forester, I put the key in the door lock to unlock the door and the alarm went off and won't stop. How do I turn the alarm off?
I would try to close the door and press the unlock button on the kay fob. (If it has a remote intergrated with the key). This should unlock the door and turn off any anti-theft devices.
Jul 27, 2012 | Car Audio & Video
2007 dodge truck 1500 hit panic on remote by accident while trying to start truck. now truck will not start.how do i reset factory alarm
most vehicle alarms, or security can be restet by closing all doors, go to the passengers door, lock and unlock it with the key a couple of time, do the same thing with the drivers side. that should turn off the security.. hope this helps
Nov 30, 2010 | 2007 Dodge Ram 1500 Quad Cab Sport
LOST KEY AND REMOTE TO A 1996 DODGE CARAVAN, i WENT TO DODGE TO HAVE NEW KEY MADE AND WAS GOING TO GO BACK FOR NEW REMOTE, HOWEVER IN THE MEAN TIME i LOCKED VEHICLE AND NOW IT WON'T REPROGRAM BECAUSE IT IS...
If unlocking the Van via the door locks wont disarm the alarm it's because the alarm harness have become detached. The door panel will have to be removed and the harness manipilated manually to disarm the alarm. Or you can have a new remote programed
Apr 29, 2010 | 1996 Dodge Caravan
Husbands 2003 dodge ram, it beeps when sets the alarm system, however, upon jumping on truck messing with door handles, alarm does not go off, why
there are all different type of alarm set ups ur truck possible set up for voltage drop (open door light goes on )sets off alarm-- if truck has aftermarket sensitivity alarm and not going off will have to adjust the unit to make more sensitive
Oct 26, 2009 | 2004 Dodge Ram 1500
2006 hard starting will not stay running, then no power at all.
What happens when you turn the key?... is there a clicking or clunking noise?... try tapping the starter and the solenoid that is attached to the starter and see if that helps. It may help if you have someone else turn the key while you tap on the starter and solenoid.
May 06, 2009 | 2006 Dodge Ram 1500
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Mar 12, 2009 | 2001 Dodge Viper
1999 Dodge Ram 1500 4WD Crew Cab - Alaram goes off when opening doors even after using key to open.
I have a 98 Dodge Ram 1500 4wd with an alarm and have the same problem. No big deal for me though as long as I have the remote. You can shut off the alarm by pushing the redlight that blinks on your console. That is usually what I do.
Aug 31, 2008 | 1998 Dodge Ram 1500 4WD
Ram Pickup Alarm  Remote Auto Start Install Cd Logo
347 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
