Question about Craftsman Convertible 25cc. Gas Line Trimmer
Motor works fine, but trimmer will not rotate
I have a craftsman line trimmer with interchangable head. motor works fine, but trimmer will not rotate
    Scholar:
  • 47 Answers
Have an assistant start and hold the trimmer. At idle, there should still be a little drag on the clutches to make the shaft spin on that split shaft trimmer with the accessory head removed. No need to rev it or do anything fancy, but teamwork will make it safer.
Now forget about the engine and clutches - does the accessory head spin freely when turned by hand (removed from engine still!) and with a clear rotation of the shaft end visible inside the connector socket? Is the shaft end square with sharply defines angles, or rounded off? Does swapping in a different accessory function normally and as expected?
Sometimes the nub end of the shaft wears. Worse, the socket on the engine side has eaten itself to pieces. Worse, worse yet, clutches in the engine side that engage the accessory shaft are worn and there is simply no transmission of power. Good luck, hopefully this info will set your boots in the right direction!
Posted on May 09, 2010
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
Jul 19, 2015 | Craftsman Convertible 25cc. Gas Line...
Why does my new Craftsman 4 cycle Trimmer's head turn counter clockwise
Curved shaft trimmers turn clockwise.. straight shaft trimmers turn Counter Clockwise. Also the Bump head is reverse threaded because of the engine rotation.
When using this trimmer , Angle the right side of the string line down so the grass gets thrown in front of you not at your legs.
May 30, 2015 | Craftsman Garden
How do you replace the trimmer head on the Craftsman 27cc trimmer (Model 711170)?
U-tube has some good videos on all sorts of replacements on heads , lines...etc.
May 13, 2014 | Craftsman Convertible 25cc. Gas Line...
Trimmer head won't rotate
Usually this is a clutch problem, the clutch is under the drum and when it engages turns the drum which turns the drive shaft which turns the trimmer head. If the drum is not turning than it is the clutch, if the clutch is turning the drive shaft could be broke, if the drive shaft is not broke than the problem would be in the gears of the trimmer head.
Apr 11, 2014 | Stihl FS 85 Weed Eater
Trimmer starts but hardly rotates when giving it gas.
Check for a tangle of grass or wire just above the string head where it attatches to the shaft. A buildup in that area can interfere with the movement of the head.
Sep 10, 2011 | Craftsman Convertible 14" Gas Line Trimmer
The motor starts and runs. The trimmer head does not rotate. I have disconnected at the coupler and I can manually move the head by turning the shaft. Any ideas?
The clutch is not working. You will need to check the clutch and clutch drum to be sure which will involve taking apart the housing to get to it. If this unit is less than a year old, I highly recommend taking it in for warranty service.
Aug 28, 2011 | Craftsman Garden
The head won,t turn
you will need to pull the head off, as it sounds like the cable is off. there should be four bolts/screws, there maybe some in the middle also, gently remove the head(this is the top of the trimmer where the pull cord is, once you have it separated you can turn the cable by hand and the line feeder should rotate, if it does then look inside the head and make sure it is still square and not rounded. or you can pull the line feeder off and pull the cord and see if the cable rotates, whichever you feel comfortable with trying. Good Luck Tim
May 16, 2011 | Craftsman 25cc Gas Line Trimmer
How do change the line? can not get head off Craftsman 25cc Gas Line Trimmer
should be a button on side of head assembly. press in and top should come off
Jul 05, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman gas weedeater. Engine runs, but the head won't run
Cut 1/8" off outer (aluminum) shaft. Lube inner shaft with STP or heavy gear lube this will re-engage worn square drive .Replacing inner cable is un-necessary this is normal wear. Sears Master Tech BB
May 26, 2009 | Craftsman 25cc Gas Line Trimmer
Need to replace entire head of Craftsman Bushwacker
there should be a little alignment hole where you can stick a small screwdriver thru to hold it from spinning then turn clockwise(its reverse thread). let me know if there isnt an alignment hole
Mar 25, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
592 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
