Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I cannot scan from my printer... Answer Everytime i click scan it says 'connecting to PC'. And then it just stops and goes back to the fax screen. How do i get it to scan to my computer It's a Brother 240c
    Genius:
  • 1,354 Answers
Cannot Scan Document into my computer after doing the following: click scan; click download to computer; clicked OK; receive message Downloading Application; then receive message cannot retrieve...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 24, 2011 | Lexmark X4690 Wireless InkJet Printer
I just got a new windows 7 laptop and my hp j4680c all in one will print and fax but not scan?
hi msplamann,
First check your printer is it copying manually from the printer screen? to copy put a page in the scanner close it and look for a button or an option in the printer which says black or color copying and press it whithout having it connected to the laptop.if it prints then you have a problem in drivers in the laptop. Reinstall them fully not partially
hope it helps!!!!
tell me how it goes
Thanks and please click the green ACCEPT button if you are satisfied with my answer
Jun 27, 2011 | HP J4680 Office Jet All-In-One Printer
How to scan a photo using hp 3050 laser jet
I'm running Windows7.
I click the start button.
I click All Programs
I look for and click Windows Fax and Scan
A window opens that is called Fax and Scan
I select new scan at the top. The PC connects with the scanner
Another window opens, and I select my printer scanner
And then I click Scan
This the easiest way that I have found to scan from my AIO
Jan 17, 2011 | HP LaserJet 3050 All-In-One Printer
Wont scan to computer
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Dec 02, 2009 | Brother MFC-465CN InkJet Printer
NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
How to connect the scanner into the computer
Hi.
Are you trying to start a scan with a button on the printer / scanner?
With your pc on and the printer / scanner on, click on "my computer" if theres not an icon on your desktop you will have to click on "Start which is on the bottom left of the screen, then on either my computer or computer" You will see a list of drives but scroll down to see if there is an imaging device connected.
If you double click on the imaging device it will open up microsoft scanner and camera wizard, follow the instructions and it will scan..
I hope that helps..
Mike
May 13, 2009 | Brother MFC 210C All-In-One InkJet Printer
I am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Mar 21, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Kodak esp 5 won't scan to computer
Here is the solution I found on the Kodak ESP 5 Support Center web page. Hope it helps or else maybe just visit the web page and browse it to see if you can find the solution to your specific problem.
Question : How do I scan from my all-in-one printer using MICROSOFT WINDOWS Imaging Acquisition (WIA) Drivers on a computer running WINDOWS VISTA Operating System? Answer : For computers running WINDOWS VISTA Operating System:
  1. Click Start > Programs/All Programs, and select Windows Photo Gallery.
  2. Click Scan at the bottom of the Windows Photo Gallery window, then click New Scan at the top of the window.
  3. Select KODAK ???? AiO (where ???? is the model number) from the Select Device window, then click OK.
  4. Click Preview and make whatever adjustments needed to achieve the desired scan.
  5. When you have made the desired adjustments, click Scan.
    During scanning, the progress is displayed.
    When the scan is complete, the file is displayed in the Windows Fax and Scan window, along with a preview of the file.
  6. Click Save as... to save the file, or click the Print icon to print the file from the Windows Fax and Scan application.
Feb 28, 2009 | Kodak ESP 5 Printer
Fax answer phone line
You set the machine up in the answer/fax mode, when a fax is coming in you have to press 9 on the phone to make it receive the fax if you pick up the receiver when it is a fax call.
You can also change the number of rings to answer a fax, I think the max is 7 rings.
Dec 20, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Not printing but fax works
  1. Click Start, click Run, type command, and then click OK to display the command.com window.
  2. Type net stop spooler, then press <Enter>.
  3. Type sc config spooler depend= RPCSS start= Auto, then press <Enter>. The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
  4. Type net start spooler,then press <Enter>.
Njoy
Apr 12, 2008 | HP PSC 2410 All-In-One InkJet Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
128 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
