Question about Dell U0636 Mouse
My dell computer built in mouse wont click on anything when i hit my left button to click it or even when i tap the pad itself...what do I do to fix it i have installed all updates
  • 998 Answers
SOURCE: dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Posted on Oct 17, 2008
  • 3940 Answers
SOURCE: Mouse pad buttons not working
If the left mouse button is not working, then it is most likely the microswitch in the button has failed. To fix, you will need to replace the palmrest assembly
Posted on Jan 04, 2009
  • 53 Answers
SOURCE: My Dell Vostro A860 Touch Pad is not working
over the top of thetouch u can find a smaall button it could hav been pressed u release tat
then ur touch wil work
Posted on Mar 08, 2009
MrDallasIT
  • 91 Answers
SOURCE: Eratic movement of cursor using touch pad
Sounds like you have a touchpad malfunction. If its an older laptop, I would recommend replacing it. Not worth the hassle of trying to install a new touchpad...
Posted on May 12, 2009
myrlex
  • 674 Answers
SOURCE: Left click mouse button broken
The same size and dimensions
Posted on May 27, 2009
Dell pushed button accidentally and email sent before i was finished
It's probably the smaller keys on a laptop that is causing this.
smaller keys means you may be inadvertently hitting an action key ( e.g. Ctrl and a button) or you may be catching the touch pad with your thumb as you type.
A tap on the touchpad is just like a click. Anywhere the mouse is on screen will be clicked... So if you have your mouse over send and you catch the pad with your thumb then it's like you are clicking.
Aug 17, 2012 | HP Computers & Internet
Hp pavilion dm4-3055dx touchpad turns on and off by itself
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 07, 2012 | Computers & Internet
Can't right or left click on inspirion 1501, touchpad is fine.
It would appear that the left/right touch pad buttons have failed. You will have 3 options at this point in time.
1) Use an external wireless mouse such as a Logitech Wireless Mouse M505 for roughly $39.99
2) Use alternative features on the laptop. Left click is typically simulated by tapping or double tapping the touch pad itself and right click can be simulated, in most cases, by single tapping the icon and pressing the pop-up menu button, typically located between the right alt and ctrl buttons.
3) Search for a replacement component online and replace the component. Touch pad replacement will require you to remove all casing screws from the laptop and then remove the case. You will then expose the screws and cabling for the touch pad. I can not give more detailed instructions as this varies per laptop model.
Sep 21, 2011 | Dell Inspiron 1501 Notebook
I have Dell laptop and the buttons on the touchpad sopped working
I would just install a usb mouse through one of you usb ports
Option 2 is to spend a lot of money to have both switches cleand/repaired
Nov 21, 2009 | Dell F3534 Touchpad
My pad wont work wen i tap on it to select only on my user account,on the other account it works fine
if you can still move the curser with the pad then tap to click is probably disabled. go to control pannel and double click the mouse icon. you will find the option to enable tap to click either on the buttons, pointer options, or hardware tabs. it varys with the manufacturer so i cannot say for sure. on dell computers, it's on the dell touchpad options tab.
Aug 13, 2009 | Acer Computers & Internet
Asus mousepad stopped working after windows vista update
1.) Try reloading the touch pad drivers, should be on the CD that came with it or check the Asus website for new ones.
2.) Have you accidently disabled it? There is a Fn key combination to do this. Try Fn+F9. Also, there is an option to automatically disable the mouse pad when a USB mouse is plugged in. And of course, you can disable it from the Device Manager.
3.) Try going into :: Control Panel, find "Mouse", select the "Device Settings" tab, select the touchpad and click the "Settings" button). Check the settings in the "Tapping" section.
Mar 16, 2009 | Computers & Internet
Dell latitude c610 touch pad left button problem
Sep 20, 2008 | Dell Latitude C610 Notebook
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Mouse Pad and Right and Left Buttons
Great job, I myself prefer to use a extra mouse rather then the built in one, if you chose to do this it wont work right away but if you give it a moment to recognize the mouse it will then be functionable.
Jan 04, 2008 | Toshiba Portege M400 PPM40U01000E Tablet...
Dell U0636 Mouse Logo
292 people viewed this question
Alun Cox
