Question about Intel D945GCCR Motherboard
Motherboard temperature more than 80c detected using speed fan
I am using a DualCore Intel Pentium D945GCCR motherboard,my mother board temperature is more than 100c when in load and when not in load its around 74c.recently i changed my power supply box because the system was booting then it goes blank and only green light was there,after changing the box,system got shut downed 3 times the reason displayed by system was shut down due to thermal event(overheating,then i download a speed fan to check temperature it showed near 100c,i did not believe so download Everest and cross check it also showed the same temperature.is the temperature any relation with power supply box.....
2 Suggested Answers
  • 240 Answers
SOURCE: motherboard temperature more than 80c
Hi Thanks for your question.
!00 C on motherboard is in fact very hight temperature. It is very dangerous for chips and stuff. You need to do few things
1. Make sure that inside of the PC is clean of any dust. Buy yourself a can of compressed air and blast all of the fans (make sure your PC is off while doing this) Dust inside can make PC run very hot.
2. What you may also do is get program that will monitor temperature and let you control fan speeds of your PC. Please click on this link--->http://www.filehippo.com/download_speedfan/ and choose download latest version in right corner.
3. Download and install Speedfan which is free Fan Control program that will monitor your Motherboard temperature and let you control fan speed which is crucial.
Good Luck
Posted on May 07, 2010
Testimonial: "thank you,the solution was helpful and i could able to know the cause and effect of the problem,i detect the temperature using speed fan only"
I have D945GCCR intel mother board ,i got an ide to sata adapter to recognize dvd writer ......but mother is unable to recognize it ......r there any driver to may it work
This board directly supports IDE. Do not use the adapter. Use the IDE port on the motherboard directly using a standard IDE cable. Good luck!
Jun 14, 2011 | Intel D945GCCR Motherboard
CPU fan runs at high speed constantly although temperature only 27 C
the fan can have dust blocking the air way to the mother board take fan off blow out put back see if it sounds any quieter.
Feb 13, 2011 | Foxconn G41MX-F 2.0 Socket 775 Celeron...
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
Dec 15, 2010 | Intel D945GCCR Motherboard
I need audio drivers for intel pentium 4 mother board
Just go to:
http://www.intel.com/p/en_US/support?iid=hdr+support
On the right side is a link to detect and update the drivers for Intel motherboards.
Thanks for using Fixya.
Nov 17, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Dear Sir/Mam I need Sound Card Drivers Intel PENTIUM-4 865GV mother board. I'm using Windoows XP2005. Also need drivers DirectDraw to play some games. Pls help me Thanks n reg Akram
hi
i found a best link for you http://www.intel.com/support/detect.htm
it detects all the drivers for you missing you download and install them you.
to draw the line you want to say directx==> Games for winodws
Aug 02, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Good Luck
May 07, 2010 | Intel D945GCCR Motherboard
Thise is Fred. A few days ago i assembled a Pentium 4
Some fans are controlled by temperature-sensitive sensors.
So, if the motherboard is "cool enough", the speed of the fan will be reduced to "zero".
Sometimes, a motherboard can enter "standby" mode.
This mode consumes only a small amount of power;
and the fan will be stopped, because the cooling it provides is not needed.
Dec 08, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I lost my D945gccr mother board's intallation cd
you can download from the intel website.
you can open the site and go to support
and download driver from your motherboard
Aug 30, 2009 | Intel D945GCCR Motherboard
Sound drivers
go here
http://downloadcenter.intel.com/Detail_Desc.aspx?ProductID=2766&DwnldID=16998&lang=eng
yours is the third one down I believe..
installation instructions are also there
Jan 19, 2009 | Intel D945GCCR Motherboard
Intel D945GCCR Motherboard Logo
235 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
