Question about Samsung Washing Machines
Samsung washer b1113j 24'' front load problem is the debris filter won't pull out when un screwed to clean & upon trying now water leaks badly when i screw it back in purchased yesterday used ?
I have the model number b1113j and the stainless steel drm on the inside is off is there any manual that can show me how to take the machine apart there is no warranty left and I am not payi g the cost to get it fixed
Posted on Feb 03, 2011
After removing debris filter for cleaning, its leaking. even when i try to remove the filter it was making 'kurk' noice and have use plyer to pull it and after fixing it water is leaking....
There maybe or was an oring on the drain cap. Make sure it is in place and use a light vegetable oil on it when you put it back in to make sure it is not binding
Dec 20, 2017 | Samsung Washing Machines
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Why does water leak after cleaning the filter?
If you have the manual handy, check the debris filter removal and reinstallation procedure. There may be some little thing that can spell the difference between leaks and no leaks.
Aug 11, 2015 | Samsung WF218ANW 4.0 cu. ft. High...
Leaking
You would need to clean out the coin or filter trap to see if debris has clogged the drain lines.
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Sep 22, 2012 | Frigidaire Affinity ATF6000F Front Load...
Not pumping out water how to clean filter
if this washer has a accsess panel to the water pump they usually have a filter that catches debris and bigger items before they go in the water pump and destroy it i have three girls at home who have lost small socks bobby pins and a multitude of other things in this cup it just simply screws out from the houseing by the water pump un plug your washer pull the acsess cover and uncrew the filter you should see it by the water pump if you could take a pic and put it on i could help direct you more
Mar 01, 2012 | Hotpoint Aquarius WD640 Front Load...
Leaking Debris Filter after cleaning and replacing
Happy to find someone with the exact same issue I'm having, misery loves company!
1st: The leak was clearly coming from the debris filter...however it was stuck and would not turn (constant clicks).
Foolishly I tried and tried again, until realizing I would need to take apart the filter to reach it.
Once that was done, using pliers I turned the debris filter, and pulled it out, there was indeed an obstruction.
After re-assembling and testing - no dice, still leaking.
I DID however, notice the grease that you had mentioned - and now after fiddling with it so much, very little if
any was left.
I ordered a new filter thinking we had ruptured or damaged it...no dice, still leaking.
Finally - I tried something a friend mentioned - plumbers tape.
With your filter off the washer and in-hand, wrap the tape around the thread of the filter head, I did this first
about 4 times around the head, and tested seeing the leaking had decreased by about 50%. Another 4 times ceased the
leaking altogether.
I can only assume that there was originally a wall of grease that stopped this from happening in the first place.
- Benji
Jan 29, 2012 | Samsung WF448AAP Front Load Washer
Tried washing an old rug and the backing crumbled in my Samsung WF209ANW front loading machine -- now the machine won't drain because I assume it's clogged with the debris. We cleaned the debris...
You will have to clean out the large black hose on the bottom of the tub. The only way to get to it is to remove the top cover from the washer then remove the front of the washer, after removing the front you will be able to reach in and remove the hose and clean out the rubber backing. You can try it from the back of the washer first and may have some success but from my experience you will have to go from the front maybe both. Good luck and have some towels ready to catch the water.
Nov 26, 2017 | Samsung WF209ANW 40 cu. ft. Front Load...
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
E1 Code - tried fixing it according to manual still won't work
The error code E1 = Water supply error -Not enough water entering the W/M.
Try check water supply line is on and not have any kinked.
Mar 21, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
231 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
