Question about E-Machines M5312 Notebook
My Laptop wont start up!
It brings me to a blue page that says a file is missing and that its dumping my physical memory. What can i do to save all my files?
  • Witold Pieczonka May 11, 2010
    Hi Thanks for your question
    Could you please provide more information so we can help you better?
    Please tell us what exactly it says on the screen...
    Please also tell us if you have any installation CD's with Laptop. Thank You
    Sergeant:
  • 180 Answers
When stuff like that happens to me or my friends, i have an external enclosures for different types of hard drives. you have to take the hard drive out of the laptop and put it in the external enclosure and hook that up to another computer and you can save your files like that. you can ge enclosures at places like best buy. ebay will be cheaper but you have to wait for it to be delivered
Posted on May 08, 2010
Dumped physical memory
Windows files are probably corrupted. Do a clean install of the operating system or bring it to a technician to do it for you.
Mar 14, 2014 | Samsung Computers & Internet
Hi, im using Ftec laptop and i have a problem today, when i click START it operates as usual but after a while a blue screen came out and says: STOP: c0000218 {Registry File Failure} The Registry...
it will be the problem with software...any recently which u installed....or application file has corrupted......its better to reload the system files from operating system cd
May 11, 2011 | Computers & Internet
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Blue screen says i need tech support
Read the complete solution please-
Depending on what the error says you may not need to contact technical support. Often this happens when the swap file becomes corrupted and since it is used as virtual memory, the OS assumes it is RAM that is defective. So it generates a system level error.
To correct this....
See if you can start in SAFE MODE, go to System Properties
Select ADVANCED tab
Select PERFORMANCE settings
Then Advanced tab again
You will see Paging File Size in the middle.
SET/Change this to 0 (zero) NO PAGING FILE
Select OK to continue
No Paging files for all drives if you have multiple partitions (logical drives)
Then save/ok your settings.
Then REBOOT
Repeat the above process and set the swap file to 2-3x the amount of ram you have in your system.
Or simple select the System Manage Size button.
(example: 1gb Ram = 2gb Virtual Memory)
Save setting and reboot again.
1: Why do I have to Reboot after each time?
because the system removes the swap file writes the changes to the registry.
2: How did my swapfile get corrupted?
sometimes a bit/byte get lost because of improper shutdown, power loss, badly designed programs, trojans and a number of unexpected issues.
3: Do I need to buy more physical ram?
only if you are using less than 1GB (with XP) or
2GB with Vista.
Good Luck
Oct 30, 2009 | Dell Latitude D600 Notebook
IBM R51 - "Registry Cannot Load"
I had the exact same problem. I basically gave up and decided to reinstall the O.S. But when I did it gave me an option to upgrade rather than install, and I found that all my programs and files were still there after. So you coulkd do that. I found out that some of the O.S. was corrupt via a virus so this was solved also.
Jun 05, 2009 | IBM ThinkPad R51 Notebook
IBM Think Pad - ''Registry Cannot Load''
Ok so what you need to do is reinstall the Opertaing System. When system 32 files are missing then the Operating System dosent work. You would need to backup any stuff you need. If you have any other questions or need directions please email me at joegoetz16@gmail.com
Packard bell versa e400
Hi
files in system32\config\ are missing or corrupt.
there is a back up stored by default at c:\windows\repair
you can copy the contents of windows\repair folder into system32\config\ and it should solve the problem, you can do it with the windows installation cd by using the recovery console.
Go into the repair folder enter the following commands in repair console
cd windows (press enter)
cd repair (press enter)
copy *.* c:\windows\system32\config\ (press enter)
files should be copied
type exit, quit or restart or reboot to restart the computer.
May 22, 2009 | Dell Inspiron B120 Notebook
Inspiron 600 m Dell blue screen
Keep pressing F8 as the computer starts up, select "last known Good Configuration" from the menu.
Jan 22, 2009 | Dell Inspiron 600M Notebook
Registry file failure
If the last suggestion i posted didn't work, you need to put in your Windows CD on boot up and when it asks if you want to repair or install press 'R' for repair, this should repair any damaged registry files and Windows files.
Nov 12, 2006 | Dell Inspiron 600M Notebook
This sounds like a previously removed piece of sofware, either a peice of a programme spyware, virus or malware, thats still got the start up files registered. Download this programme, it's very good, it's free and has no spyware attached, it will remove all traces of unused registry files and temporary files. http://www.filehippo.com/download_ccleaner/ If you still have problems click Start>Run and type 'msconfig' without quotes. This will bring up a window; click the startup tab and see if there are any unrecognised programmes on start up that you no longer use.
Nov 09, 2006 | Dell Inspiron 600M Notebook
E-Machines M5312 Notebook Logo
60 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
