Question about Kitchen Ranges
I need a replacement grease filter #06124-02 for hood model # 106-2S
  • smith230 Mar 30, 2008
    Very helpful. I have the part ordered and it saves me a lot of expenses relative to buying a new range. Thanks again.
    Great help. I would have had to abandon the old range except for this assisstance.
  • 5,911 Answers
I found the part number listed at searspartsdirect.com, but it does not show an illustration. The orginal part number you provided has been discontinued and substituted as #Y0612402. The part costs $23.99 and is listed as a filter, however. I found the part by using the "Find a Part by Part #" on the front page. For confirmation there is a toll free number and email address under the "Contact Us" menu. I hope this helps you.
Posted on Mar 27, 2008
SOURCE:
I'm trying to buy a replacement filter. What the part number?
hello. go to searspartsdirect.com
enter your model number
click on model
you will get a schematic showing the parts, and you can order the proper filter there too or at least get the correct part number for your model. joe
Apr 15, 2011 | Frigidaire HD4130 / HD4130W / HD4130Q...
How do i reset the grease filter indicator icon on the display on my arietta range hood
From the manual: To reset the grease filter saturation alarm the user must press the "+" key for 5 seconds, after this action the icon "grease filter" is not display [sic], and the hood has the normal display operation.
Feb 19, 2011 | Microwave Ovens
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
I am trying to remove the filter from a tappan range hood model HD1442I I see clips on each side of the filter but they don't want to move.
They are more than likely stuck from grease take a butter knife and slid it between the hood and the screen and break the grease seal all around the screen then try removing it by pulling on the tabs at the same time in one direction away from the frame it should come out. You can go to Wal Mart and buy Super clean to clean the grease out of it and the hood as well. Be sure to wear rubber gloves when using the super clean, it's in the automotive section if yo have a spray bottle you can buy the gallon jug it's like $7.00 for a gallon and $4.99 for 10 oz. spray bottle and I use it on everything cars stoves washing machines and any appliance that needs cleaned it is a very powerful cleaner. Hope this helps, if this does not do the trick let me know and I will give ya some more advice but pretty sure it's just the spattered grease holding it in place. Hope this helps and thanks for using fix-ya.
Jan 19, 2010 | Tappan TEF242 Electric Kitchen Range
How do you replace the charcoal filter in a Homark cooker hood (model no. 02 500560)? The whole filter spins round a short way but doesn't drop out.
Try giving it a slight pull as grease sometimes acumulates and stops it from dropping past the lugs that hold it in place.
Oct 05, 2009 | Kitchen Ranges
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Dirty range hood filters
You can purchase grease filters for only a few pounds from many super markets, these can be cut to size to suit your hood. Changing charcoals filters is more expensive but should be done every couple of years depending on your usage.
Mar 18, 2009 | Kitchen Ranges
Exaust vent/ fan very weak
In your duplicate post, you mentioned your model, so here you go:
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Dec 10, 2008 | Microwave Ovens
Neff cooker hood
the manual i have says that the charcoal filters inside need changing about every 6 months. take out the grease filters then you should be able to turn it and take them out. you may not have these if the extractor vents to the outside. the grease filters can be cleaned with a neutral detergent and then put back in. Make sure the electric is off before you do any of this. Hope this makes sense and helps!
Jul 09, 2008 | Kitchen Ranges
Filters for the Kenmore Downdraft Blower
CAN YOU PLEASE GIVE ME THE RIGHT CUTOUT FOR THIS DOWNDRAFT
Nov 13, 2006 | Kenmore 59940 Kitchen Hood
Kitchen Ranges Logo
128 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
