Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fischer Paykel smartdrive washing machine
My ten year old Smartdrive has just developed a problem where it continual stops and starts every two seconds or so until it just errors with a beeping sound. I have tried it on multiple programs, just spin and so on to no avail. I'd be grateful for any advice. Time for a new one??
R=Thanks
Jon
  • 4 more comments
  • jonhatton May 08, 2010
    Hi and thanks for the response.
    The control board is grey. Hope you can let me know what to do next.
    Thanks
    Jon
    Not sure if my earlier response got there, the unit is grey.
    Thanks for any further help you can supply.
    Regards
    Jon
    Regards
    Jon
  • jonhatton May 09, 2010
    Hi, Thanks for the last response. I have found the microswitch and while the contacts don't look too bad the switch itself looks dodgy in that having gently pushed it in it has now stayed in. Do I need to try and find a replacement or can you prise it open to clean it up? Or is there a way to just by-pass it?
    Thanks again.
    Hi, I have now managed to clean up the switch with a pin and its running nice and freely. Put it all back together and the machine is running like new! Given its Mother's Day here in Australia my wife is so pleased I don't have to send her out to the laundry-mat ;-)
    Thank you so much for your help.
    Best regards
    Jon
  • luisa_sgro May 11, 2010
    sounds like your out of balance switch is faulty. to fix this fault you need to remove the top 2 screws holding the top panel to the machine. remove the panel gently, but be careful as it has the wires to the keypad attached . now what color is the control board ? it might be brown, grey, blue, green or yellow. please reply and i can guide u thru the next part to fix this fault. please turn off the power first do not want any accidents.
  • Fisher and P... Master
  • 713 Answers
Ok. first remove the keypad wires to the control board. then remove the screw holding the control board to the frame. the switch is underneath [to the right] of the control board. looking at the switch you will have 2 wires to it, [it is just a normal microswitch]. now be careful on this next part, remove the switch from where it is clipped in. remove the 2 wires to it. does it look corroded?. see the little button on it, push it. is it clicking positivity? have u got an electrical test meter? u need to test for conductivity between the 2 contacts that the wires were on. if u have no conductivity then that is the problem. please reply back with answers to the questions and i can guide u thru the last part to fix this fault.
Posted on May 08, 2010
  • luisa_sgro May 09, 2010
    glad i could help. i posted the last reply getting ready to go to a mothers day lunch. if u have any more problems please reply. good luck with the machine .by the way the one thing that causes this fault is the use of warm or hot water. it''''s the steam that corrodes the terminals. have a good one and bye for now
Smartdrive excellence
Check the lid magnetic reed switch for corrosion or swelling and continuity when lid is closed.
Aug 01, 2013 | Fisher and Paykel Fisher & Paykel Washer
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel washing machine Smartdrive 703 Advance, Power and Start buttons are non responsive when pushed. Is there a part that can fix this. Does the control panel have to be replaced?
Fisher & Paykel Smart Drive beeps and stops during rinse cycle. If I hit pause and wait and restart it eventually continues. It seems like it has problems detecting water level.
Apr 13, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel smartdrive lets water in in spurts then stops
might be an overload. remove some clothes and retry. I have the manual here on my site:
Use the sire search to find it
http://sites.google.com/site/sublimeappliancerepair/Home
Aug 31, 2009 | Washing Machines
Fisher paykel Washing machine stops spinning then resumes.
This sounds like it could be a faulty door lock switch. The switch can be tested for continuity using a multimeter. A lack of continuity indicates a faulty switch. Hope this helped and best wishes.
Aug 05, 2009 | Washing Machines
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
476 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
