Question about American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le
Americast tub has a scratch
How to repair a small scratch on surface of NEW americast bath tub
  • 25 Answers
Try rubbing some toothpaste over the scratch with your finger you will be amazed
Posted on Jul 12, 2010
I want to clean the jets in my tub they look mouldy
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link at the bottom to the cleaning products I can find right now. There may be others out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Feb 27, 2014 | American Standard 9330.014 Adhesive Bath...
We have got a black scratch in the bottom of our white plastic bath can this be fixed
How deep is the black scratch? Is it a scratch of just a black mark that doesn't want to come up.
If you have not tried it yet, get some Denatured Alcohol and use it to clean the black mark. That is a really good cleaner that will not harm the surface of your tub.
US Parts Center
Sep 04, 2013 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
The drain was dropped in the sink and we thought it was a scratch but it is a small chip you can feel.  I read about epoxy but is this going to be too thick, being it is a very small
I assume this is a new sink and you are trying to save it. There are several options depending on how much time and or money you want to put into the repair. The simplest is what you mentioned yourself. just be sure to clean the surface completely, you may want to use rubbing alcohol to be sure there is no oil or contaminates on the surface. Be sure the area is completely dry before applying the epoxy. There are several types and you will have to determine which is closest as a match for color and sheen. With that said dip a toothpick into a small drop of epoxy and then transfer it to the desired location. Keep in mind that it will more than likely be higher than the existing surface. Once it has completely dried, 48 hours for a good cure, then take a single edge razor and gently press it to the surface and push it along at a 25-35 degree angle to remove the high spot. You may need to do this several times to get the desired finish.
If you are not happy with this then you can have the whole sink refinished professionally by a number of companies. I have used Bath Crest with good success.
Jun 30, 2009 | Home
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
I HAVE A AMERICAST TUB AND AM WONDERING IF I NED A MOTARBED UNDER THE TUB?
its not a bad idea i always did and never had a problem use strucolite lite weight cement
Feb 22, 2009 | Palm Thermocast Sea High Gloss White Cast...
How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Feb 07, 2009 | Whirlpool Home
2748.328 Town Square 5' x 42" Air Bath Tub Won't Work
Air bath tubs have a preset time limit. it could be that it reached that limit. Especially if the lights are still lit up on the control.
Dec 29, 2008 | American Standard 2748.328 Town Square 5'...
I have a chip in my bath tub
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Dec 09, 2008 | Home
American Standard Cambridge 5' Americast Bathtub w/ Grab Bar Drillings & Le Logo
192 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
