Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Believe it or not our dog got in and is stuck. Is
Believe it or not our dog got in and is stuck. Is there any easy way to remove the agitator so he can get out?
3 Suggested Answers
SOURCE: Agitator Dogs
To disassemble, you need to destroy the tabs that are holding the translucent thing to the four post on top of the bottom part. This of course means that the translucent thing needs to be replaced too. I hammered the screwdriver into the tabs until they gave way. The rest of teh parts come out undamaged.
(if you have snips with really long handles, that would be a better tool).
Posted on Dec 12, 2008
jumptrout51
  • 3361 Answers
SOURCE: Removing old dogs to replace them
Take pliers and pull it hard. It will come loose.
Posted on Apr 06, 2009
+whirlpool LSQ8243HQ0 water valve works. wont wash or spin. new motor coupling and timer.
Under the agitator you have what is called (agitating dogs). The agitator will have to be removed. The top should spin off, you will be able to look down into the agitator and see a bolt. Remove this bolt and the agitator can be pulled out. The agitators are small pieces of plastic with small teeth. These teeth get worn out over time or if the washer is overloaded. When the agitator free spins one way the teeth grab a (gear) on agitator and this is how you get the washing action (agitating). These dogs are easy to replace and cost about $5. If you need more info check out *how to replace agitating dogs)
Dec 15, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Re Kenmore Model 110, need to replace the 4 ''dogs'' in top part of agitator. Top of agitator won't come off. Suggestions?
Remove the center bolt. Pull the agitator out and turn it upside down and the cam and dogs will drop out in your hand. Use a strap under the agitator for leverage if it seems stuck, .
Eric
Dec 24, 2009 | Kenmore Washing Machines
Not agitating
does it have the dual agitator
Aug 06, 2009 | Amana NTW5205TQ Top Load Washer
Agitator does minimal agitation
Hi Omni,
The Agitator "dogs"/cams have given up the ghost and need to be replaced. Access to them is easy. Before starting the repair, have this part in hand.
Here's a tool list;
1.) small flat screwdriver (to remove the top part of the agitator)
2.) 3/8" ratchet
3.) 8" X 3/8" extension (for the ratchet)
4.) 7/16" socket
Take a gander at this pic... you'll be going after #10 'cause that's the problem.
All you gotta do is remove the top parts from the agitator to access it. See #2 in the diagram? That's the bolt holding the agitator to the transmission shaft. Remove that, then lift the whole agitator out of the tub. Now place the agitator on the floor and put both of your feet on the base. Now lift the agitator (#3) off the base (#4). Place one of your hands into the opening of the top of the agitator (to hold the cam (#9) in place) then turn the agitator over. The cam will slide right out.
Now you'll see the cam "dogs"... little white curved plastic doo-hickeys. All you gotta do now is install the new cam assy. and rebuild the agitator! Cool, huh? All it takes is about $15 bucks in parts and ~20 minutes.
Let me know if you have further questions. And don't forget to rate my solution as "FixYa"! Thanks, BB
Apr 14, 2009 | Whirlpool LSQ9610L Top Load Washer
Mixing center spindle won't aggitate
Your agitator dogs are worn out.
Remove the agitator and replace the 4 little rubber dogs.
Snap the top off. Remove the bolt inside. Pull up on the top part and access the dogs.
Mar 26, 2009 | Whirlpool Washing Machines
Top agitator not working properly
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way).If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
Agitator dogs part number is 80040
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Removing clutch assembly from agitator
easy bud, take the top off the agitator then you will see a cover. pop that off and you will se a bolt. remove and take off the middle prt of agitator and you can get to the dogs
Feb 16, 2009 | Whirlpool Washing Machines
Spin cycle with agitation motion occurring simultaneously
Hi again,
Appreciate the "Ask Me".
I believe the dampness is due to slow spin speed as you also have concluded. And I suspect that partial winding of the motor is the culprit. Hence, replacement is in order.
As to your concern why the agitator also operate during the spin setting, it could possibly be stuck or locked agitator dogs. Agitator dogs function is better explained here by another FixYa member, jsrock516.
Cheers.
Jul 25, 2008 | Washing Machines
We have a modle # LLR7144DQ0 - the agitator is not working properly. It is not pulling the clothes down into the water.
The agitator 'dog ears' have worn out. Very easy to replace.
  • Remove fabric softener or protective cap on top of agitator
  • Remove center bolt securing agitator.
  • Lift out agitator and replace dog ears.
Jun 23, 2008 | Whirlpool Washing Machines
Kenmore 8series washer
to remove the trans you have to remove the agitator, lift off cap on agitator there will be i believe a 5/16 or 7/16 bolt remove that carefully because dog ears right at top will fall out, slide out agitator and tran should come out.
Apr 26, 2007 | Kenmore 15864/15862 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
