Question about Karcher 2500 PSI Pressure Washer
I had a problem regards on my car pajero GDi V.6 3.5. if you will step on tha pedal for brake especially on the traffic jam the engine will stop.what seem to be problem of my car? thanks you
    Brigadier General:
  • 4,090 Answers
A short circuit in the brake switch that will stop power to the distributor and coil I believe.
please rate my help++++Thanks for using FIXYA
Posted on May 08, 2010
I have a pajero 3500 gdi 1997 model, that is light engine check in dashboard and can't accelerate more than 3000 rpm.
ECU has logged an error code. YOu need to read it out with a tester and then fix the reported problem or clear the error code.
ECU goes to safe mode with reduced power if certain errors are logged.
Regards Winfried
Apr 12, 2017 | 1992 Mitsubishi Pajero
Where can I find the high pressure pump on and the Mitsubishi pajero GDI and the fuel pressure sensor?
I don't think there is a pump, it is done with engine oil pressure at the injector.
Jul 12, 2016 | Mitsubishi Cars & Trucks
Diagnosis of APS Sensor on GDI Mitsubish Pajero
You really need a scan tool to diagnose this problem.
Nov 17, 2015 | Cars & Trucks
My Pajero GDI engine v6 petrol has idling and acceleration problem.
it is a possibility the potension meter does not working. It is on the accelerator pedal,by using a scanner surely you will get the correct fault.
Mar 06, 2013 | Cars & Trucks
Mitsubishi Pajero Exceed 1997 Model Engine #6G74 GDI V6 3500,no power,I suspect its the engine control unit,I order the ECU,but still no power,probably its crankshaft and camshaft sensor.
I solve this problem with Mitshubishi Pajero GDI 6G74 like this: remove the two little filters from the high pressure pump and ,if necessary, insert a external gasoline filter.
Mar 24, 2011 | Mitsubishi Montero Cars & Trucks
My car stalls when slowing to stop or crawling in traffic.
i had the same problem on my 95 pajero 3500 andafter all my troubles my car produced an occasional airfilter blow back from running on gas before it finally would'nt run my problem turned out to be my crankshaft sensor was failing then died.
Mar 14, 2010 | 1997 Mitsubishi Montero
Mitsubishi pajero
It should be on the cyllinder block just below the head
Aug 27, 2009 | 1998 Mitsubishi Montero
Karcher 2500 PSI Pressure Washer Logo
159 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
