Question about HP Vs17 17" LCD Flat Panel Monitor
Power light on flashing but no screen
I have a 2006 hp vs 17 monitor the problem is it powers on but no screen the power light just flashes
    President:
  • 3,278 Answers
Hello.
There is either a problem with your monitor, VGA cable or PC's video connector. Try another PC or another monitor to narrow down your problem.
If another monitor works, swap the VGA cable on your old monitor.
If another monitor doesn't work, your video connector is faulty.
Hope this helps.
Posted on May 08, 2010
How do I change the video connector? I have the 'I have a hp vs 17 e monitor the problem is it powers on but no screen the power light just flashes' symptom and changed the cable with no improvement.
The power light flases can mean it is not geting the signal from PC or it is in shutdown protection mode. Try it on another PC first. If it does the same then you will need to open it up, but you should read below at look at my pictures albums to get some idea what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | HP Vs17 17" LCD Flat Panel Monitor
My fathr gave me a hp f1703 monitor. As soon as i plug it in the whole screen flashes on and off. The light on the power cord also flashes, but if i unplug the monitor and leave the speakers plugged in the...
try another monitor i re placed my cord and the graphics card and it didn't do me any good i replaced the monitor last and it works fine now. and my speakers pluged into the monitor the monitor i bought didn't have the port for speakers so now i need to get usb speakers so check it out. hope this helps
Oct 17, 2009 | HP Pavilion F1703 17" LCD Monitor
Power led on hp monitor flashing
mham2525, Did it have a "perfect" picture on it yesterday? You do know that if the COLD-CATHODE-FLUORESCENT-TUBES that are hung on the rear of the LCD PANEL fail to light, all you get is a BLACK screen to look at!!!!! OMG, What shall I do now???? It sure would be nice if all we needed to do was remove the cover and then screw-in 4 new CFL light bulbs into our monitors. YOUR UNIT WILL NEED TO BE TROUBLESHOOTED AND REPAIRED. MOST LIKELY A SMPS/INVERTER BOARD FAILURE. CALL HP TO SEE IF THEY HAVE A SWAPOUT PROGRAM. Bye for now. lmistyrel @aol.com
Sep 24, 2009 | HP Pavilion F1703 17" LCD Monitor
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Hp pavilion f1703 blue monitor power button flashesw/ dark screen
Have you tried connecting this monitor to another computer, even a laptop. This would tell you whether the display is bad or the video card is the culprit. I suspect the monitor's power supply is dying. Taking it to a pro for repair should cost @55.00. Buying a new monitor @ $100 - $125.
Mar 26, 2009 | HP Pavilion F1703 17" LCD Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Pavilion 17" screen flashes on and off
Try reinstalling your monitor. You should have a disc that came with all of your equipment.Make sure it is a clean install and there are no other programs running. Also check all connections to make sure they are tight.
If this does not help, do you have another monitor you can install temporarily so that you can work on this problem?
Is this a new monitor installation? You might want to check your hardware compatibility list which you will find under Start>Programs>accessories>compatibility wizard.
Aug 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
My LCD power light flashes orange and screen is blank and there is afaint ticking noise coming from the monitor. Can anyone help?
Due to still having a power light you can bet the power supply is still fine.
The problem will be in the inverter circuit, but more to the point it's actualy one of the CCFL tubes that has blown.
They can be easy to replace, they can also be a complete nightmare.
Hope that helps =)
Sep 21, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
HP Vs17 17" LCD Flat Panel Monitor Logo
422 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
