Question about Garden
I have an older yardpro riding lawnmower with a 18hp kolher when i turn the deck on it starts to discharge & will kill the battery eventally, if i shut the deck off it will charge, looking for ideas to search or solution
    Scholar:
  • 110 Answers
Faulty voltage regulator. Insufficiant output to operate the PTO clutch and charge the battery.
If the battery charges without the PTO clutch 'IN', then this proves all the wiring, so this has to be the answer.
I suppose there is a remote possibility that the holding coil in the clutch is partially shorted, but it's unlikely.
Posted on May 08, 2010
What battery does a 48" deck riding mower take
I would put in the largest amp lawnmower type battery you can get
Aug 07, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
HOW TO FIX LAWNMOWER
I will need a few more details about your no start condition. Does the engine just click or does it turn over and just won't start? What are your battery amps? Did you check for spark? Do you have fuel?
Jul 16, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
I have a lawnboy self propeled mower model #10533. the serial number is 6907889. i do not know where the spring-choke return spring goes. if i had a picture of it installed i could do it becuase i am not...
For getting big view of picture please click on the link below http://www.ask.com/bar?q=lawnboy+self+propelled+mower+model+%2310533&page=1&qsrc=19&dm=all&ab=5&u=http://www.partsandservice.com/html/Lawnboy/Lawnmower/10533.html&sg=jTUCMw17SUPaA/y4FH3G/QzzCbOKvHGnvkxGP%2Bp36m4%3D&tsp=1276102809824 Part number 5 is what you want to see in the fig and fit. 1 1 Housing, Deck (Incl. Ref. #2 & 40)
2 1 Decal, Danger
3 1 Decal, Deck
4 1 Shield, Trailing
5 1 Spring, Extension
7 2 Screw, Hex Hd.
8 1 Ramp, Discharge
9 2 Screw, Shoulder
10 2 Clamp, Hinge
11 2 Bolt, Wheel
12 2 Knob, Arm
13 2 Washer, Flat
14 1 Seal, Door
15 2 Screw, Thread Form.
16 1 Brace, Door
17 2 Pin, Hinge
18 4 Nut, Lock
19 1 Decal, Warning
20 1 Door, Discharge
21 1 Panel, Vertical
22 2 Spring Arm ***'y, Front
23 2 Bushing, Door
24 1 Cover, Access
25 2 Hanger, Shield
26 1 Cable, Door
27 1 Handle, Hood
28 2 Screw, Tapping
29 3 Screw, Tapping
30 2 Seal, Door Side
31 1 Seal, Door End
32 2 Tire & Wheel Assembly, 8"
33 4 Washer
34 2 Arm, Pivot
35 1 Bracket, Discharge Ramp
37 1 Panel, Screen
38 1 Screw, Thread Form.
39 2 Bolt, Shoulder
40 1 Decal, Warning
41 1 Decal, Instructions
42 2 Cap, Hub
43 1 Decal, AppliqueThis are the parts in your mower.Thanks. keep updated for any morequery.you can rate this solution and show your appreciation.
Jun 09, 2010 | Garden
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding lawnmower older Craftsman 143406012 12hp searches for rpm/
the needle valve on carb is out of adjustment it should be turned all the way in & out 1-1/2 turns to 2 turns try that & let me know if i can further help ya
Jun 23, 2009 | Craftsman Garden
Battery discharing light is on
Does your tractor have electric clutch ? With the switch turned off try removing positive battery cable you then try touching cable to post if you get a spark you have a short in system you could also charge battery and remove positive cable from battery over night to see if battery stays up to check battery,you also have a alternater under flywheel to charge battery you should be getting an output of about 14 volts most likely not the problem
May 05, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
