Question about PC Chips MB PCCHIPS K8T800 M860 V1.0 Motherboard
I attempted to flash my bios and now my computer won't boot. Blank screen of doom.
  • 1 more comment
  • the_number_z May 08, 2010
    Any idea where the cmos cell is on my board?
    Any ideas?
    Using the reset jumpers didn't fix it. Removing the battery didn't fix it. Ideas?
  • 12,061 Answers
Well this is a real problem, it depends on just how bad it is, we call this "Bricking" when we muck up or have a bad "Flash" we say we have "Bricked" our PC, now there is indeed a reason for that "Saying" and that is, that that's what it is now, an expensive brick, as this is all it can be used for, once a PC, has had it's BIOS made inoperable, for whatever reason, it is unrecoverable, unless you have a backup BIOS already onboard, or were able to physically remove the CMOS ROM IC, and replace it with a correctly flashed BIOS ROM. There is no way back, as the BIOS is what tells the PC how and what to use, timing data all sorts of crucial things that if incorrect will simply not work,ever.I am sorry to tell you this but, it is best you know.
The ONLY shot you have, is to try an Flash the BIOS again, but I don't hold out much hope...below is a recovery link, for ACER, and below that is another link that may help, the last link, is how to unbrick, a motherboard BIOS.
http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
http://mydellmini.com/forum/bios-upgrade-utility-split-from-bios-upgrade-failure-topic--t1063.html#p7011
http://www.google.co.nz/search?num=100&hl=en&q=how+to+fix+a+bricked+motherboard+BIOS%3F&aq=f&aqi=&aql=&oq=&gs_rfai=
Posted on May 08, 2010
  • 4,281 Answers
If bios upgrade process was not completed then it is very danger for motherboard.
Again try to upgrade your bios to newest version then check.
Pull cmos cell from motherboard for 10 minutes so all settings reset.
Reattach the Ram memory processor and it's fan.
Make sure motherboard is not ground with cabinet.
Then check.If after upgrading bios same issue then you need to repair your motherboard chip at nearest computer center.
Let me know if you need further assistance.
Thanks for using FixYa.
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
My screen dont light on my aspire 7250
I have just fixed an Aspire 7250 with following symptoms: Only blue Power LED or battery charge LED come on, fan spins, no backlight, no video either on internal screen or VGA output.
Problem solved desolderig BIOS flash chip (W25Q16) and flashing BIOS 1.10 with an universal programmer.
Aug 06, 2012 | Acer Computers & Internet
Err1err3
There are several issues that can cause this err1err3 issue. It could be a bad hard disc (or a bad wire between the drive and the motherboard), an incorrect BIOS setting for the SATA hard drive or a problem with the master boot record (MBR). Make sure that there is no disc in the CD drive and disconnect any external storage devices (flash drive). Your computer may be trying to boot from a non-bootable disc.
To check the BIOS setting, turn off the computer and turn it back on. Press F10 continuously to access the BIOS on an HP computer. Some HP computers use F2 or F6. There should be a splash screen that tells you which to use. (If you see the error again, try this step again. It's easy to not have the key press noticed between the POST and the attempt to boot the computer.) Once in the BIOS, go to the Advanced Settings tab (one to the right) and go down to the SATA1 controller option. (Try AHCI.) Then press F10 to save and exit. (Note this isn't part of the BIOS on all HP machines - it does work for some.) See if there is a Diagnostics tab in the BIOS and try running the hard drive test.
Get an hard drive testing utility (ISO) and burn it to CD on another computer. You can set the first boot location when you go into the BIOS as above. With the bootable CD in the drive, restart the computer. (Some machines let you set the one-time boot location by pressing F12 on start up; as with entering the BIOS, it's easy to miss the timing. Just repeat the attempt.)
If the disc tests as good, you can try to repair the MBR. Use a repair tool or an OS install disc for your version of Vista (Home Premium). Boot from the CD as above. With the install disc, follow the on- screen directions and select the Repair option. You will need to enter the Command line mode. You'll need to enter Bootrec with the correct option. For more information, see the following document: http://support.microsoft.com/kb/927392 .
If you possibly can, remove the drive from your current computer before trying the repair. Use a USB/IDE/SATA adapter and another computer, see if the data on the disc can be copied to make a back up. This will work if the disc is still good. (It will also indicate if the cable was the problem if the disc failed the diagnostic tests.)
I hope this helps.
Apr 16, 2012 | HP Pavilion Computers & Internet
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Whenever I turn on my laptop the screen is blank with a white dash mark flashing in the top left corner of the screen. What do I do?
That is the signal that the BIOS no longer finds an operating system installed on the hdd. All you are left to do is to reinstall it. Use the recovery disk that came with it.
Jul 05, 2011 | Acer Aspire 6920 Notebook PC
Windows wont start up when computer is turned on, at the bottom of the screen, it just says press f for set up or tab for bios memo, then the screen will be blank with just a cursor blinking
If you are interested in solving the problem more easily and quickly. I think you can try this computer boot up suite, a boot CD and several other data rescue tools that help get your PC going even if Windows won't start or computer won't boot up at all.
Jun 25, 2011 | ASUS Eee PC 1000H Laptop
My notebook from one moment to another black screen appears a lock in the corner and I asked for a password, I can do? hopefully can help me. thank you very much from chile.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
now for the password
If you are talking about problem with your password
You need to prepare:
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
or
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
or
http://majorgeeks.com/download.php?det=5710
UBCD4Win is a bootable CD which contains software that allows you to repair, restore, or diagnose almost any computer problem also has a bios reset tool which can remove your password and bios password
you will have to burn it to a disk as an ISO then you will have to boot from the disc During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart (note after you have removed your password you will have change first boot back to your hard drive) Hope this helps
Apr 12, 2011 | Computers & Internet
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
PC Chips MB PCCHIPS K8T800 M860 V1.0 Motherboard Logo
88 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
