Dryer just stopped working
not much to go on here, but if you hear anything that sounds like a motor running, then I would suspect a broken belt. There is a belt that actually runs around the drum that makes it turn.
If you don't hear a motor running then you need to check your controls and cable(with a volt meter(just start at the motor and work your way back).If you hear a motor then its probably the belt that gos around the drum and motor( a little tricky to replace but not hard)
