Question about Microsoft Windows XP Home Edition
How to set up windows xp to laptop without using cd rom
    Scholar:
  • 47 Answers
HELLO BROTHER ITS VERY EASY TO INSTALL XP THREW PEN DRIVE PLZ CONTINUE THESE STEPS TO INSTALL XP THREW PEN DRIVE
STEPS:-
1.
http://files.extremeoverclocking.com/file.php?f=197/</code>
CLICK ON PRIMARY DOWNLOAD SITE & DOWNLOAD USB DRIVE BOOTABLE TOOL
2. AFTER THAT ON THE ABOVE OF THIS PAGE CLICK ON
http://files.extremeoverclocking.com/file.php?f=196/</code>
3. COPY XP FILES ON PEN DRIVE WITH FOLDER NAME(WINXP)
4. BOOT FROM USB
5. AFTER COMPLETE BOOTING U WILL SEE THE PROMP C:/>
6. C:/>SMARTDRV
7. CD WINXP
8. C:/WINXP>CD I386
9. C:/WINXP/I386>WINNT
10 NOW UR COMP START SOME FILES AFTER COMPLETING THIS UR COMP WILL RESTART
11. DOESN,T REMOVE UR PEN DRIVE BUT SELECT OPTION BOOT FROM HARD DISK
12. DONT FORMAT THE C: AND CONTINUE UR INSTALLATION AS A BOOTABLE CD
Thankyou
Amit Bhardwaj
Posted on May 11, 2010
2 Suggested Answers
lolita
  • 385 Answers
SOURCE: extracting cd images like ISO,NRG,MDF etc.
You can download PowerArchiver program to extract these types of files. it works great. You can get it at this website.
Thanks,
Lolita
Posted on Jul 21, 2008
Hello! Here is my problem; I have Gateway MX6426 laptop and CD drive went off. When I try to install Windows XP from external CD drive some problems occurred. I put CD in ext.CD drive,run clean...
Press F1, ie for Gateway to enter Bios settings.
Go to your BIOS MENU,
From "Boot options" set 1st boot to "removable drives" save the setting, ie if you are using an external CD/DVD or USB flash drive. If you are using an external CD/DVD Rom, ensure that the power supply to the external CD/DVD Rom drive is sufficient.
Try and reinstall the Operating System again.
Hope it helps, and good luck.
Oct 11, 2010 | Computers & Internet
I purchased a compaq M 300 laptop without a hard-drive,and CD-Rom. Now I would like to install Windows XP using a hp MB cradle I recently purchased but the unit is not reading the WinXp cd-rom. How can I...
u have to bootable disk of win xp.then set first boot devicce in bios your dvd rom or cd rom.
then u get message pres any key to boot from cd .wehn u start the ssytem.
then follow the procedure.
press enter.
then create parttion.
as u like.
thejn simple follow the procedure.
Oct 11, 2008 | HP Computers & Internet
Tip
How do I backup my files and folders in XP?
Windows XP comes with a backup tool called NTBACKUP (NTBACKUP.MSI from Windows XP CD-ROM). In Windows XP Home Edition, this tool has to be installed manually from the CD-ROM, whereas in Windows XP Professional, this tool is installed by default.
Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD to start a wizard that installs NTBackup: X:\VALUEADD\MSFT\NTBACKUP
X:\ refers to the CD-ROM drive-letter
Note: Usually, OEMs such as Compaq, DELL won't ship the Windows XP CD nor they include the NTBACKUP utility by default. You can download a copy of NTBACKUP.MSI here
Backing up your files using NTBackup Utility:
Click Start, Run and type NTBACKUP
Select Backup tab at the top
In the left pane, scroll to the file/folder which you want to backup and put a checkmark on it.
At the bottom, mention the output filename (the backup output)
Once set, click Start Backup button in the right, and again click Start Backup in resulting dialog
NTBACKUP does not have the ability to write to CDs directly. You will need to save the backup to hard drive, then transfer or burn it to a CD-ROM. Also, while backing up several files, make sure you backup the files in separate sets of each max 650MB (so that it fits on a CD-ROM)
See also FREE Windows Backup Software add-on for NTBackup
Enhanced Windows Backup uses Windows' built in backup engine called Windows Backup (ntbackup.exe) which provides state-of-the-art core backup technology. Enhanced Windows Backup substantially extends the capabilities of NTBackup, providing an effective integrated backup solution.
on Mar 24, 2008 | HP Compaq Presario V2000 Notebook
My laptop is not detecting cd in it wht to do???????????
connect an external cd/dvd drive & see if its working or not. If yes, then you need to replace cd/dvd drive of your laptop.
Jun 16, 2010 | Acer Extensa 4620 Notebook
How do i reboot my window vista xp laptob if I
Your DELL computer should have been shipped with a set of "System Restore" CD-ROMs. Reinstall Windows from those disks.
If you don't have the disks, telephone Dell, and they will courier-ship a set of CD-ROMs to you.
Nov 06, 2009 | Dell Latitude D520 Notebook
Toshiba tecra m2v s330
Try borrowing a compatible HDD instead of buying a third one for testing and check if the same error exists. Try also using an external DVD drive to see if your internal CD-ROM is defective. Try also using another Windows XP CD installer. You can also use other OS installation CD to check it. Otherwise, there is something wrong with your lappy's motherboard due to tear and wear, heat, vibration, misuse and shock.
Mar 20, 2009 | Toshiba Tecra M2V-S330 Notebook
I want to replace my windows 98se to windows xp
u have set bois u have to set frist boot device usb cdrom the u can able to boot from the usb cd rom
Jan 11, 2009 | Microsoft Windows 98 for PC
WIN XP won't start
You have to set the BIOS to boot from CD-ROM, so it should be the first one. Then from the installation screen you have to press r to try and repair your windows installation. This should work without losing your data.
May 15, 2008 | Toshiba Satellite A35-S159 Notebook
Windows could not start
you can use any xp disk.re install fresh copy not repair.im sure you know someone who could lend you a copy for couple of hours
Feb 20, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Microsoft Windows XP Home Edition Logo
105 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
