Question about Garden
When starting mower, the choke resist opening and the engine coughs and sput gas out of the muffler. If I manually open choke, the engine comes up to operating speed and once warmed up, choke remains open by itself. If I remove the fine wire tension spring from choke, it starts cleanly and runs fine. Is it OK to run the mower without the spring attached or is there some other way to adjust that tension? Or am I totally pursuing the the solution to the problem wrongly?
  • 61 Answers
I'm not sure this will be of any help, however, try spraying WD40 on the choke butterfly. It may be a little sticky from varnish from old gas. Be sure the butterfly is moving freely.
Posted on May 09, 2010
Testimonial: "Thank you. I will do this. It has to help. Additionally, I put a capful of carburator cleaner in the gas tank. Perhaps the float may be sticking too."
How do I adjust a manual choke?
A manual choke utilizes a lever and cable assembly to open and close the choke plate. If your mower has the manual set up check the adjustment by pushing the lever to the stop in one direction. The choke plate should be either all the way open or all the way closed. If not check the cable hold down clamp, there is a retaining screw that holds a small clamp over the cable to hold the cable housing in place. Now if the choke is not adjusted properly then watch to see which way is not going full motion.Then loosen the retaining screw and slide the housing one way or the other to achieve either full open or full close and retighten the retaining screw. Now remove the spark plug and look at the electrode end and see what color the porcelain is, if it is black then it needs to be replaced or cleaned. If it is white then there is not enough fuel and the engine requires more choke to draw more fuel when the engine is cold, remember that after the engine starts and warms up to open the choke so it does not flood the engine - you will see black exhaust qnd the engine will not run smooth,
Aug 30, 2015 | Gcv160 Gas Engine
Automatic choke will not shut off once the engine is running so engine dies. Could it be a spring is missing ?
There is a diaphram that the link connects to the choke. It is between the carb and the gas tank, and runs by the vacuum from the engine. B&S engines have to rev up for the choke to open all the way.
Sep 20, 2014 | Cub Cadet Garden
Where is the choke
Many Briggs engine have a primer rather than a choke, the 675 series has a choke that is worked by an air vain, the choke is always closed when the engine is stopped, once the engine starts air pressure from the flywheel pushes the air vain which in turn opens the choke to allow the engine to run normally, there is also a version with a bi thermal switch on the back of the muffler, as the muffler heats up the switch opens the choke.
Feb 12, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
I have a 74 gmc pu with an 87 350 motor that i put in. I put new edelbrock itake, carb, headers ,new pipe and mufflers, wires ,plugs .It starts, idles, and drives good even at normal or cold operating...
The fuel mixture is wrong because either the carb is badly adjusted or the choke doesn't open fully when the engine is hot.
Take the carb apart and check every single component, starting with the choke plates and the level in the bowls.
Jul 30, 2011 | Chevrolet C2500 Cars & Trucks
When I try to start my weedeater gas comes out of the muffler
It is flooded something fierce. The gas will come out of the muffler when it starts flooding the cylinder. Once you get it starter (no choke when flooded, throttle open) it will smoke like the dickens and then should be fine.
Apr 07, 2010 | Garden
I have a 455 rancher that is difficult to impossible to start. If I get it started and stop it it won't start back. when it starts it runs fine. I took the plug out and cranked the engine and there was a...
my 455 did this also I went and bought a new gas filter new gas and mix. try this you might have some water in your gas,also add some sea foam additive to your gas mixture just about a table spoon to 2.5 gallons of gas
Feb 23, 2010 | Husqvarna Garden
Will only run with choke on or barely open doesnt want to rev up have done carb kit fuel lines comp. check fresh gas, primer bowl wont stay full and gas in tank bubbles around a lot
Check the exhaust muffler, it might be blocked with carbon. Remove the muffler and start the engine, see if it runs. Soak the muffler in petrol overnight. Stephen.
Nov 09, 2009 | Garden
13.5 OHV B&S won't stay running, blows gas out carb.
Check to see if the oil is over filled. check if the oil smells like gas, could be a gas leak into the crank case.
More than likely the head gasket is blown internally, causing excessive crank case pressure
Aug 15, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
