Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
    Champion:
  • 222 Answers
This is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
Posted on Jun 09, 2010
  • FLUFF
    FLUFF Jan 04, 2015
    could he bridge them thus cutting watts in half ?
I have 2 12" Pioneer TS-W3003D4 subs and I wanted to know can a Pioneer GM-D8500M run them?
pretty much any amplifier can run any sub, so the question is not weather or not the amp can run them, it is how well the amp can run them. Those Pioneer subs are dual VC models and are rated at 600 watts RMS. You have two, so that would be about 1200 watts of RMS power you will need in order to power the subs correctly and to optimum efficiency. The amplifier model you have is rated at 600 watts RMS for a single channel at the lowest stable impendence. That power coming from the amp will be split two ways between the subs and divide the power to each speaker. So each speaker will be receiving 300 watts of power. So in short yes, your amp will power those subs, but they will only be operating at half their rated power. Your amp will be running at maximum power so it might get a little warm after a while. make sure you wire it correctly and keep the amp well ventilated if you decide to push it that hard. if you need help on how to wire them search the web for wiring options by typing into Google " how to wire two dual voice coil subs into amp". There you will find plenty of illustrations to help you decide.
Aug 25, 2015 | Pioneer Car Audio & Video
Can you run a 1200w pioneer sub and 2x9x9 inch car speakers to a 600w pioneer 4 channell amp??
depends on what the RMS is for the subs because although the subs are 1200 watts, there is a minumim standard you have to follow. If you don't atleast run the lowest wattage thru them, then you will most definately damage the speakers....you should also be aware of the fact that your "600w Pioneer-4 channel amp doesn't even push a true 600 watts... Your best bet is to upgrade ur amp, or add an additional amp to your set-up. And you really need to pay close att to over or under running your power to your stereo system because you'll burn out ur altenator rather quickly. Use proper wattage , and you should also look into getting a power-cell which lessens the chances of destroying your altenator and helps to ensure that your stereo system sounds to its full potential.....
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
I have a ts-w307d4 pioneer sub woofer and its a 4 ohm sub that has 4 terminals on it 2 red and 2 black how do i wire this sub to my amp i have a sony 1200 watts stereo amp and my sub is a dual voice coil...
conect one of the positive terminal from the sub directli to one chanel of the amp, and do the same with the negative,and do the same with the others terminals from the sub conect to the other chanel
Aug 12, 2010 | Pioneer TS-W307D4 Car Subwoofer
How should i wire my sub
if your amp has a bridge do nt bridge the subs just connect them normal planet audio subs usually dont have a high potential to withstand too much watts even if the subs say 1200 watts thats not true nwatts check the box the subs came in it will tell u true wattage it may say rms
May 24, 2010 | Nitro BMW-481 Car Audio Amplifier
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Subs wont pound
could be the wiring or not enough power getting to the amp or check your grounds
Sep 18, 2009 | Pioneer GM-7200M Car Audio Amplifier
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Is it enough to power to 12 volge=ahagen 12oowatss dual 4 ohms
your Volfenhag 12" subs are rated at 1200 watts they are only 600 watts rms and the Rockford punch p4004 is only 200 watts rms so the answer is yes it will work but if you get a amplifier that pushes out 500 - 600 watts rms you will love the sound from subs
there is nothing wrong with the Rockford amp it just wont pound out the bass as hard but the good news is you will never blow the subs with it
when buying amps or subs make sure to look at rms rating that is the true power they actually have ie. (sub box says 1200 watt you think powerful but if you divide it in 1/2 you actually get 600 watts rms) don't get me wrong that's a nice rating. for a sub but you will want to match that number with the amps rms rating or lower. The RMS is what makes the car pound the higher the RMS the better
hope this helps
Mar 05, 2009 | Rockford Fosgate Punch P4004 Car Audio...
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
213 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
