Question about Kenmore 93702 Top Load Stacked Washer / Dryer
Kenmore 110 model purchased in 1987
Instead of cold water for the rinsing cycle, the water is lukewarm. Is this easily fixed or is it time for a new washer and dryer?
  • 1 more comment
  • Appletaker Apr 25, 2008
    I thought if it was in the control panel, we could easily get to it or if the valves were somewhere outside the machine, we could do that too. Help!
    Beth
  • Appletaker Apr 26, 2008
    Telling me that it could be one of two things is NOT
    Telling me that it is one of two areas on the washing machine is NOT a solution! I need more than that! I need some specific directions.
    Genius:
  • 3,587 Answers
Really? that's unusual...sounds like the mixing of the hot/cold water is not working. could be control panel, or the actual valves.
you particularly handy, or do you usually have someone do this sort of thing.
Posted on Apr 25, 2008
Washer stops in rinse cycle
your contacts swithces for rinse cycle inside timer could be burned or bad..very model I will locate part number
Dec 15, 2007 | Washing Machines
Rinse cycle not working on Kenmore 600?????
sounds like a program prob not familiar with this mech but it seems suspect
Mar 01, 2015 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Kenmore heavy duty 80 model 110. rinse cycle at cold is down to a trickle, and seems to be lessening. Takes hour plus for a full water load if mixed alright flow for warm and hot
Your cold water line is clogged, kinked or the water valve solenoid is not opening all the way. First check the hose, then the screen on the valve for clogs. If none then replace the water valve assembly.
Dec 15, 2010 | Kenmore Washing Machines
COLD WATER WILL NOT FILL; NO COLD WATER RINSE. MODEL NUMBER 110 26452502
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 08, 2010 | Kenmore Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
I have a Kenmore washer. the water temp switches by itself.
IM NOT SURE HOW YOUR WASHER IS SET UP ON TEMP SETTINGS BUT-- THE RINCE CYCLE IS ALWAYS COLD RINCE
Nov 03, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
Feb 23, 2009 | Kenmore 46462 Front Load Washer
Kenmore 93702 Top Load Stacked Washer / Dryer Logo
93 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
