Question about Asko W6021 Front Load Washer
Asko w 6021 still having issues
I replaced the carbon brushes as you instructed and now the washer runs. It does not switch cycles automatically now only manually and when I placed it in postion 10 spin cycle it worked fine then started to drain and continues to drain. This is even after the machine is turned off and unplugged for awile. When it is restarted it goes right back to the drain cycle and does not shut off. Anymore help would be appreciated.
    Sergeant:
  • 351 Answers
Does it keep draining on any cycle and with the door open if so have you done anything with the pressure switch or the pressure sensor(red and black) it sits behind the pressure switch you may have to replace them.also check the board for any burn marks,i think you said you replaced it last time?if you have pressed down on the top of the pressure sensor you will have to replace it.am able to give you my mobile no or not.not sure how this site works.Ian
Posted on Mar 28, 2008
How to change asko 6021 brushes?
You're better off just replacing the whole motor. It will save you alot of time!
Apr 30, 2012 | Asko W6021 Front Load Washer
Asko 10505 washer will not spin
Hi, 2 things to check for. Obstruction in the drain pump or faulty drain pump, brushes in the motor worn out. The easiest way to determine the pump issue is answer this question. Does it drain ? Next, turn the timer to the drain/spin cycle, obviously it should drain & spin and advance to "off". The next thing with these 10505 asko is to see if the drum rotates in both directions in the wash/agitate portion of the cycle. You can just select the short wash for this (I forget if it's #4 or #5) If not, it's worn brushes. However, you'll have to make sure the armature isn't damaged before simply installimg new brushes. We can cross that bridge when we get there. Let me know. Hope that helps, though those are just the most common problems there could be others. Good Luck
Nov 01, 2009 | Asko W6021 Front Load Washer
I have an Asko front load washer W6221. I have
I had identical problem. I diagnosed it to be the motor brushes on the front of the motor. They have an off switch in them when they get worn out. Easy to check and replace. Remove front lower panel (two torx 20 screws). Brushes are visible and are held with two screws each. One on each side of motor. Remove two screws on each brush and unattach wire. Two new motor brushes were around $75. Literally tooke 30 minutes to replace. Hope this is your issue!
Oct 14, 2009 | Asko W6221 Front Load Washer
Our asko 6021 washer is spinning at high speed, but not draining. Could the drain hose be plugged? How can we check this? It doesn't appear to just screw off.
hi..If the drainer does not work the problem could be
it may be a worn or loose drive belt or a solenoid switch
that is not working.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Asko W6021 Front Load Washer
Asko Washer W6021 Problem
CHECK THE BRUSHES ON THE MOTOR, FOR BEING WORN DOWN!
REGARDS........TREVOR. FLEETWOOD UK.
Mar 09, 2009 | Asko W6021 Front Load Washer
W640T2 (CIRCIUT BOARD)
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
Sep 13, 2008 | Asko W6461 Front Load Washer
Asko w6021 washer not working
replace the carbon brushs in the motor,they will be worn out part no 8801195,round motor.or 8801097 square motor.
Mar 23, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
306 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
