Question about Polaroid TDA-03211C 32 in. LCD HDTV
Turn on tv, picture comes on breifly, then off
My mother turns the tv on. The picture comes on then goes off while the sound is still heard.
polaroid TDA-03211c
  • 1779 Answers
SOURCE: have a Polaroid TDA-03211C tv with dvd player. Won't play DVDs
As long as you know a disc is not stuck inside I recommend taking it to your local svc center to be looked at.
Posted on Mar 04, 2009
RNS-Systems
  • 120 Answers
SOURCE: screen black. polaroid tv 32". have sound TV/DVD Combo TDA-03211C
sounds like inverter board. What it sounds like is happing is your LCD is working ut the backligkt board that allows you to see is kicking off. (as you still have sound) Which could be the (most likely) inverter board, or the power supply board. You can take apart and check for voltage at your power supply. The power supply has a pigtail with large white wires and a connector. Power up with the center back cover off and check your voltage at the white connector on the power supply before and after the screen gos out. If there is no large voltage loss it is your inverter board.
You can used boards on e-bay or
www.rns-systems.com
Posted on Oct 16, 2009
SOURCE: polaroid tda-03211c no picture
I was just looking at my manual for mjne and there is a fuse behind the set in a small plastic box you might check it
Posted on Oct 30, 2009
  • 4 Answers
SOURCE: no pictuer polaroid tda-03211c
my unit would come on and after a short time the picture would go to black I placed an small fan on the back of the unit the additional cooling worked butthe fan noise is distracting looking for a better solution
Posted on Nov 17, 2009
budmrtn
  • 11361 Answers
SOURCE: no Picture only sound polaroid tv tdx 03211c
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Posted on Nov 25, 2009
Picture goes in and out
Looks like a problem with mother board. Call LG and they will replace the mother board in around Rs 7000/-
Jun 21, 2014 | LG 55LE5500 55 in. HDTV LED
Polaroid tv screen goes black after 30 40 minutes, sound is good. No picture. Turn set off and wait a few minutes and the picture returns for a few minutes then goes black again.
Ur tv now power on only have picture few mins,than dead,have sound only?Yes,than the 1 or 2 the long board call the LCD inverter boards are dead.The LCD inverter long boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy 1 or 2 long LCD inverter boards for the replacement.
Jul 05, 2010 | Polaroid FLM-3232 Television
Polaroid tv goes immediately off after turning on
Ur tv power supply board is defective.That the board where the a/c power cord go into it.Replaced the power supply board,ur tv will have stable power and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 27, 2010 | Polaroid TLA-04011C 40 in. LCD TV
TV Has Sound but no picture
Change or move yellow one, of the cables, or component. if not then something you need from expert..
Dec 31, 2009 | Polaroid TDX-02610B LCD TV
Everytime i turn on my lcd tv it turns on and the pictur goes off
there are flourescent tubes inside that can be replaced, they help to alluminate the screen. There are these other boards inside that can malfunction too, best to take the unit to a technician.
Dec 13, 2009 | Polaroid 4226TLMB 42 in. LCD TV
No picture on 32" Polaroid
Your inverter boards need to be tested and serviced, these are circuits designed to control the light behind the LCD glass panel. It could also be the power supply not feeding 24volts too the inverter circuits. In that case the power board would need servicing.
Take it back if its under warranty if not get it serviced at your local repair center..
Nov 08, 2009 | Polaroid TDX-03211C LCD TV
My tv is not turning on anymore. It turn on but there picture or the logo (Polaroid) doens't load up. It doenst turn off, i have to unplug.
Sounds like the main mother board is the problem. Basically, it's the brains of the TV and it controls everything. The replacement board may cost about in the $200 range. Being that the board is not cheap, best to have a TV tech confirm the diagnoses. Most TV techs come to your home and charge about $50 to look at it.
Replacement Board can be found at a good price at Shopjimmy.com or E-bay.com.
Oct 26, 2009 | Polaroid FLM-4034B 40 in. LCD HDTV
TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Sep 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
While watching the TV the picture suddenly went out - still have sound. Turning the TV off and on again does not help - the POLAROID Logo displays, but when the station connects - still no picture
possibly external power supply faulty under load it may fail these power supplies ofen have capacitor failure open the power supply to check for leaking/bulging/swollen capacitor is around 2000uf rated at 12v
Apr 28, 2009 | Polaroid FLM-2011 Television
Noise coming from power supply
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Sep 18, 2008 | Polaroid FLM-323B Television
Polaroid TDA-03211C 32 in. LCD HDTV Logo
132 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
