Question about Gateway Computers & Internet
Trying to disassemble MS2274 Gateway laptop--
In short, the power/charger adapter inside the computer is not doing so well. The needle inside became a little loose. Anyone got any ideas as to HOW to take this thing apart so that I can get to it?
You need to replace the DC Jack it will involve soldering a new part. most time the whole laptop need to be taking a part to get the it, so unless you are ready for a big challenge take it a tech.
Posted on Jul 25, 2010
Gateway MS2274 Laptop has a black screen and not booting. The power indicator comes on and all you hear is the fan and soon afterward will shut off; no hard drive LED. Tried removing the battery and...
Sounds like a severe hardware problem concerning your laptop's hard drive. I suggest you contact Gateway customer service to check on your warranty - your laptop is, simply put, broken. The best approach to repairing it is not to fix it yourself in this case.
Mar 13, 2011 | Computers & Internet
I have a new charger cord when plug in back of computer my computer want charge up
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Mar 10, 2011 | Gateway M-7315U Notebook
If I need to repair or replace my gateway mx6448 motherboard, which is most cost-efficient: to repair or replace? How would I know the difference? I am not an expert, but can I do this repair or...
Depends on what is wrong. Is it the DC Power Jack? The jack you plug the AC adapter (Charger) into?
Average cost is around $100 for a DC Power Jack replacement. (It's labor intensive, but the jack itself usually runs around $8 to $14 )
Most computer 'repair' shops do not have the skills required to perform this procedure.
The easy way is to just replace the motherboard. (Also more Ka-ching in the pocket)
Just a typical DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Disassembling a Gateway MX 6000 series laptop,
http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
Some designs of the motherboard, have the DC Power Jack mounted in an area on the motherboard, that DC Power Jack failure is a reoccurring failure.
The motherboard cracks in the area the DC Power Jack is mounted. (Breaking the circuit traces)
In this instance it's better to replace the motherboard. Of course it's going to fail later on.
Your question: "Can you replace the motherboard?"
I have confidence in you, I believe you can.
Doesn't take a rocket scientist, but does require patience.
1) Remove ALL Power to the laptop. AC adapter (Charger), and Battery.
2) It would behoove you to buy, and wear an ESD wrist strap. (Electro Static Discharge)
Connect the alligator clip to a good ground source.
I connect to the metal frame of an empty desktop computer case.
(Average cost is around $3 to $8. Look online for reference. Visit computer repair shops, and stores like Radio Shack for purchase)
Your body carries Static electricity. Static will fry out (Short Circuit) the hardware components inside a computer. Especially a Processor.
With wearing an ESD wrist strap, and connecting to a good ground source, your laptop is safe.
3) There may be as many as 60+ screws. There may be 12, or more different types of screws. DO NOT mix them up! Use a multi-compartment container, and label the compartments for the area the screws came out of.
You can use a clean egg container, (Or two) in a pinch. label each egg holder.
4) You may want to take photos, and make notes as you disassemble. Makes a real handy guide for reassembling. Also nice to have if you get interrupted in the middle.
Obtaining a motherboard:
You might check Ebay. Sounds like advertising, but it isn't. Just one of my sources.
Also check Laptops for Parts on Ebay.
Some sell a laptop that has a broken LCD screen as the only fault.
Post questions in a Comment.
This is what the motherboard looks like, (Gateway Support),
http://support.gateway.com/s/Mobile/Q106/BladeK8F/4001199R/4001199Rmv.shtml
Oct 13, 2010 | Gateway Computers & Internet
Okay if my gateway m285 pc tablet wont turn on how do i know if its the charger or the battery itself?
just do a simple test. plug your charger in AC mains, at the jack end, insert a wire and then try to make instant contact with the jacket of the jack. you will see a brief spark. If spark is there, it means your adapter is good. rest you know that if charger is ok and still laptop is not working it means that there is something wrong with the power section inside the laptop. Even with a bad battary, if adapter is good, laptop will work, provided power section of the laptop should be ok.
cheers
Sep 04, 2010 | Gateway M285-E Notebook
My Gateway NV5386u battery died and the computer shutdown. When I tried plugging it in, it still would not turn on. The adapter part of the charger has a green light, indicating power is being applied, but...
Often when a battery is real flat, it hangs up the entire system. What you need to do, is remove the battery completely, as the laptop should be able to be powered by the AC adapter itself. You may find if that is the case that your battery has gone bad, and you will have to replace it. If your laptop, will NOT work from the AC adapter, then either the adapter is faulty, or there is an internal vault, in the Power conditioning circuitry inside the PC. Try another adapter, if still no go, then it is definitely an internal problem.
Jul 16, 2010 | Gateway NV5386u 156Inch Laptop (Blue) PC...
The charger for my laptop will not charge it. I used the charger from another Gateway laptop that I know works and yet it didn't on the 1st laptop. It appears that the male section which is inside the...
No, you can remove the battery, if the AC adapter is supplying power to the laptop.
Since _two_ AC adapters do not work, it's most-likely that the problem is your laptop.
Take the laptop to a qualified technician; they can try to disassemble the laptop, and fix the "bad" connector.
Apr 18, 2010 | Audio Players & Recorders
Gateway mt6705 doesn't charge
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 26, 2009 | Gateway MT6705 Notebook
My family has a Latitude D610. Recently my younger sister pushed open a door between a power outlet that the charger was plugged into, and a desk where the laptop was (also plugged in to the charger). The...
See link here to troubleshoot the no power on condition, and see link here and here for checking ac adapter for damage and replacement.
Try removing the battery, disconnecting the ac adapter, and pressing the power button down for a few moments to discharge the unit. Then reinsert the battery and perhaps it will power up...But better to replace that adapter & perhaps have a local technician take a look at it to remove the broken pin before you cause any further damage to the system....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 25, 2009 | Dell Latitude D610 Notebook
Toshiba Satellite charging problem.
Since you used to have to shake the computer to get it to work, my first guess would be that the power connector inside the laptop has became loose. Unfortunately this can be very difficult to repair. It usually requires completely disassembling the laptop and resoldering the connector.
However, if you can find someone with a laptop that takes the same charger - or if you can find a PC repair shop that has one they will let you test with - you can test it that way.
Mar 11, 2009 | Toshiba Computers & Internet
GATEWAY LAPTOPS NOT CHARGING...WE NEED TO GET FILE COMPLAINTS WITH BOTH BBB AND GATEWAY AND THEN SUE THEM IF NOTHING HAPPENS...
I was told by the computer repair company the connection is arching back and shorting out the chargers. To have a connection replaced would be $150 so that is what we are going to do. We have gone through 4 chargers on our gateway also.
Jan 12, 2009 | Gateway MX8711 Notebook
Computers & Internet Logo
2,107 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
