Question about Brother DCP-7020 All-In-One Laser Printer
Brother DCP 115C blank screen display
The LCD screen on my DCP 115C is blank, have tried turning on and off and turning on whilst holding menu but nothing works, please help!
  • 1 more comment
  • seahauck Mar 30, 2008
    I have the same problem withmy DCP 7020 -- I think it started after a static discharge. Brother did not respond to my request for help
  • scullythedog Apr 06, 2008
    Same thing on my Brother 7020 . . . LCD screen is blank. It prints OK but you can't change anything using the input keys since the screen is blank.
  • Tony Walker May 11, 2010
    Does the printer work normally even though the display does not?
5 Suggested Answers
Mix-it-up
  • 832 Answers
SOURCE: machine error A7 ( brother dcp 115c )
Did you change the scanner cover? This happens when a wrong cis type is installed. The rom data has to be set again (this can only be done by service personal)
Posted on Nov 10, 2007
Soulvisitor
  • 1113 Answers
SOURCE: I need total reset for a Brother dcp 115c
Your print head is stuffed. More expensive than new machine, Release your frustration with this unit by placing neatly in bin!
4F
The head drive voltage has
dropped from the high to
low level in an abnormally
short period.
why
Piezoelectric (PZT)
ceramic actuator
defective (Cracks or
rare short)
Posted on Feb 07, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP 115C displays unable
press menu then start b/k-copy (mono) then fortimes arrow up button quickly after another. machine will switch to mainteance mode. press start bk copy.
What two digit error code does the machine display?
Post here again.
Posted on Mar 09, 2008
Mix-it-up
  • 832 Answers
SOURCE: Brother DCP-115C unable to clean
you need a new waist ink absorber box from a service partner which can be found at brother homepage of you country.
After replacing the box you have to do a reset.
search error 46 or unable to clean here in the forum. it has been written many times.
Posted on May 05, 2008
mickspaceNET
  • 115 Answers
SOURCE: brother dcp-115c driver download for windows xp 32
This is a link to the Brother website
You will need to select OS sys, Language etc
Posted on Oct 30, 2008
My printer wont turn on or LCD screen blank.
Hi! Please check the power cord. THe power cord may be faulty and needs replacement. If you can swap a same cord please do it to confirm that its the cord. Hope this helps and have a good one!
Jun 20, 2010 | Brother DCP 115C All-In-One InkJet Printer
Fails to clean and nothing seems to make it work
First step is to find out the error in MAINTENANCE mode.
- Switch off the machine by pulling out the AC plug
- Switch on the machine with holding the "MENU" button down. Keep holding it until you see some info, then release....
- What kind of error pops up in the display?
Oct 09, 2009 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean problem
turn the rpitner of then check there is not any paper jam.
also refix crtridge after clean it.
Jan 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Brother dcp-115c driver download for windows xp 32
Oct 30, 2008 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Jul 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
I cant to move my DCP-115 to the maintanance mode
First button is MENU then start b/k copy then 4x arrow-up....
Mar 01, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP-7020 All-In-One Laser Printer Logo
200 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
