Question about Acoustic Research 900MHz Wireless Stereo Headphones - Black
Lost manual and can't remember how to hook up
We haven't used the headphones in a while and can't remember how to hook up
Panasonic KX-TG933T 6.0 Lost directions. Need to program phone call in code from outside to retrieve any messages. Can't remember what my code is.... Thank you Ann Marie
If you haven't changed it, the remote access code is 111.
You can download a copy of the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
The remote operation instructions begin on page 37.
Jul 12, 2011 | Lands Phones
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
Lost my operation manual and can't remember how to change the entry code. Linda
Here is a link to the installation manual for your lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
You will find the reprogramming steps here. I'd suggest replacing the 4 AA batteries at this time, if you haven't already done so.
May 21, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
My system is stuck on (c2) headphone and I can not any sound, unless I put the headphones in.
Hi Steve,
This is an indication of faulty earphone jack, this is where the headset directly hooked up. See sample picture below.
When the you hooked up the headset to this jack, internal switch will released the contact to cut the audio goes to the main speaker out of the unit. Once you pulled out the headset plug, the audio will back to the main output speaker out through this switch.
In your cased, there's a malfunction in the internal switch of the earphone jack that's you haven't sound output at the main speaker out.
You may spray contact cleaner directly to the earphone jack while inserting and pulling out the headset plug to clean the lead. If the symptom still persist, you must replaced it with new one to back the unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
May 17, 2011 | Sony DAV-S400 System
How do I hook up my blue tooth headphones to my onkyo SR 605
You cannot rig up a blue tooth headphones to this receiver with out a blue tooth transmitter ( the Onkyo does not have one built in ). If you have a transmitter it can be plugged into the headphone out socket of the Onkyo ( in front ), just remember that it will cut out the sound from all your speakers when you insert the headphone jack . The advantage though with this connection is you can control the headphone volume using the Onkyo remote.
Mar 12, 2011 | Onkyo TX-DS656 Receiver
Where to hook up headphone jacks to allow TV speakers to continue working while using headphones I.E. I have jacks on front of TV but they do not give me out put sound. which ones should I use on back of...
Unless you have an external headphone amplifier, you need to use the headphone jack socket, if there is one. Some newer TV's allow for separate headphone volume and speaker volume control.
Have a look in your user manual.
Jan 08, 2011 | Panasonic CT-36D20 36" TV
Can I stream mp3 to Bose lifestyle50
Sure, you can hook up any mp3 player to this system. What you will need is a headphone to stereo RCA cable. Then, plug the headphone connection into the mp3 headphone jack and the RCA ends into your Bose aux input.You can use any of the inputs (Video 1, 2, Tape) just remember which one you are plugged into.
May 03, 2009 | Bose LifeStyle 50 System
Acoustic Research 900MHz Wireless Stereo Headphones - Black Logo
388 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
