Question about Durabrand DUR7 Portable DVD Player
Have a dse potable dvd player GE4203 would like to connect it to a tv. is there a cord i need to get and what does it look like??
How do you connect a potable dvd player?
If the dvd player has a hdmi contact you should use this. In the tv's menu you should be able to define the hdmi contact in use. The same goes for a scart contact. However, if the dvd player has a cart contact only and the tv has no scart contact, I am afraid that you cannot use that player. Anyway, you should consult the manual, that you have been adviced to download. Good luck.
Aug 06, 2014 | Hannspree XV32 32 in. LCD Television
I have a **** Smith GE4203 DVD player, but none of the "MPEG4" files I plug in with a USB stick works. The machine recognises an AVI file, but doesn't play it. What settings should I use?...
Rip your DVD's using XviD format and not DivX and they should play just fine.
A good free software to try is "Winx Free DVD to XviD" but you'll have to have unprotected DVD's or rip them to the hard drive first using DVDFab to remove the protection or just have Slysoft AnyDVD running.
I set the video's audio to mp3 format (128Kbps 48000sample rate), and the video to 25fps(because in Australia we have PAL format), output profile to keep original size and aspect ratio, and video quality to about 1500kbps.
You won't get much benefit from a higher bit rate then that on a GE4203 screen and you could probably even go lower if you have speed or sync issues with the data rate. Even 1200 looks good.
May 28, 2011 | Televison & Video
How do I connect my philips dvd750vr dvd player to my tv? (tv is a toshiba cx32f60). thanks
it all depends on the cord that you want to use. There are different cords that can be used to connect Tv to your player.
But I would recommend RCA cord. RCA cord is a Yellow, white and red wires. The yellow stands for video, while the white and red stands for audio left and right.
Look at the back of your TV, connect the yellow part of the cord to Video IN, the connect the red and white to Audio IN respectively.
Now, connect the other end of the wires to the player in the format; Connect the yellow to video Out, the connect the red and white to audio Out, respectively.
Turn on your TV and Player. Press source or AV on the TV remote and a display of the DVD will appear on the screewn of your TV.
That would be all.
If you still have difficulty in connecting, please let me know so that I can help further.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Philips DVD750VR DVD Player/VCR
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
I need to replace the LCD screen
The best bet is to get in touch with the brands closest authorised repair agent and thet should be able to order the parts for you. Good luck.
Nov 15, 2009 | Jwin JD-VD108 8.4'' Portable TV/DVD/CD...
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Nov 05, 2009 | Televison & Video
Lost power supply cord for Dynex DX-PD510
Tries it own website yet?Tries Amazon.com,or ebay.com have many eclectronics acessories.Or go to ur local Radio Shack ask the clerk for help to buy.These potable DVD use very comon power adaptors.
Nov 04, 2009 | Dynex DX-PD510
Unlock code for DSE G2112 required
Hi, I recently bought this model too. I spoke to **** Smith themselves and they assured me that the G2112 is region free out of the box. Have you had a problem?
Feb 17, 2008 | Televison & Video
Durabrand DUR7 Portable DVD Player Logo
237 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
