Question about RTO Farm Pro 3 Point Hitch Cultivator Tractor Plow Farming
Oil leak on farm pro 3 point tiller.
I have a farm pro 3 point hitch tiller. Its leaking oil from the bottom of the gear box. I'm trying to break down the shaft to get to the oil seals. I can't remove the bearing thats on the shaft and its right in front of the oil seals. I do I get this bearing off?
4 Suggested Answers
  • 6 Answers
SOURCE: hello , my reverse gear is worn on my mf35 , my
no shouldnt do un-less the bearings are worn badly, which is very hard to do.
Posted on May 19, 2010
farmerbear
  • 490 Answers
SOURCE: Is the gear box on
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Posted on Aug 21, 2010
  • 5687 Answers
SOURCE: my to30 P.T.O shaft is
Hello, I have in front of me a catalog for Valu-Bilt.Com, a tractor supply company for all makes. Your Seal can be one of several depending on the Serial number of your tractor. There phone number is 1-888-828-3276.
The Catalog I have shows a Model 35, but I see you have a Model 30. I believe the transmissions were different between the 30 and 35, but see no reason for the rear end to change. The later Model 35 had more gears like a Sherman unit. The Model 35 had a model with 2 extra forward gears and the model used as a Front Loader had 2 extra in both Forward and Reverse.
Now Ferguson and Ford were similar, with the Ferguson having more innovations. Check with a Ford Dealer for PTO seals. The Continental engine was desired as it had Overhead valves and more power over the Ford.
You may also get lucky with Tractor Supply who carry some parts. One additional thing is the number of teeth on the PTO shaft. The book shows a 17 tooth, 25 Spline as 1868528M1 for the Model 30 PTO shaft. The Model 35 has 10 Splines in both a 17 and 19 tooth shaft.
So it is possible you may not even have the original PTO seal if someone put in a part for a Model T35.
I hope this is helpful and would like to know if you found your part. Thanks
Posted on Jul 03, 2011
What oil do I use in the Botton Gear Box
90 weight gear oil GS-90 same as motor cycle is what I use.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 03, 2016 | Garden
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
I have an oil leak from the engine. what could the problem be
Check the sump gasket at the rear of the sump tension sump bolts. Check that the rocker cover gasket is not leaking down the back of the engine and giving the appearance of a sump leak. Rear crank seal would be another point of leak and front input shaft (clutch shaft) seal leaking. Check the engine oil level and correct if necessary and check gear box oil level and correct if necessary. If you have an auto the oil will be pinkish and indicates a torque converter to gear box seal leaking.. Either of the shaft seals will require the box removal for repair.
Apr 05, 2013 | Cars & Trucks
Jerry, I just want to service the gear box on my front end tiller, I guess just opening it and adding grease. Anything else that I need to do to this 40 + year old tiller?
Is the gear box still good? In a lot of older tillers the gear boxes go bad. This is normally due to weeds getting wrapped around the tines and rubbing away at the seals in the end of the gear box. If you have to add oil (grease) then the seals are probably leaking. You should not have to open the gear box up, there should be a plug in it. The plug should be about half way between the bottom and top of the gear box. You should be able to fill the gear box up to that plug with a squeeze bottle. Please rate my answer so I am rewarded points for it.
Jan 29, 2012 | Mtd Garden
How much gear oil for gear box and gear case
most gear boxes have a bottom drain and a side fill plug , you fill until the oil runs
out of the top plug
Oct 18, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
The oil is leaking from the gear box of my automatic transmission
what box?? gear box are described as tranny, differential and steering box. if steering is leaking check the seals at input shaft or bottom replacement is nessary but can be done pretty easy and cheap too. if leaking from hose then you looking as a hydraulic hose like $80 or so..
Feb 16, 2010 | 1998 Toyota Corolla
Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
Sep 13, 2009 | Garden
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
Nov 18, 2008 | Kenmore KSM100 Stand Mixer
RTO Farm Pro 3 Point Hitch Cultivator Tractor Plow Farming Logo
87 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
JOHN BROWN
Are you a RTO Garden Expert? Answer questions, earn points and help others
