Voyager A210 Laptop shows when connected to wifi "Limited or no connectivity"although others are connected on same router at the time. I have removed wifi program and reinstalled No difference
    Scholar:
  • 67 Answers
This is just a try. Find out the Default Gateway on the other computers. If they are using a static IP then you need to get on. At someone else's computer click Start and Run and enter Cmd and click OK.
Now type in ipconfig /all. Look for IP Address, Subnet Mask, Default Gateway and DNS Servers. Write it all down. Then find an available IP address by using the Ping command.
In the same Window, type in ping and the IP Address of the computer you are at. That's just to show you what it looks like when you find an IP already taken. You'll see "reply from..." with the address you just pinged. Now ping again but change the last octal in the IP (the last number) in the IP address to something under 256. And ping again. Do this until you get a message "request timed out". You've just found an available IP.
Posted on Mar 27, 2008
SOURCE:
My Dell laptop will only connect to public WiFi with limited connectivity
Follow the following steps to resolve Wifi issues on your Laptop. Open Control Panel - Select Network and Sharing Center - Manage Wireless Networks - Highlight your Wifi Network - Right Click and Remove. Reset the TCP/IP stack of the windows system with limited connection status.
My laptop is showing limited Internet access over my home WiFi - Quora
https://www.quora.com/My-laptop-is-showing-limited-Internet-access-over-my-home-W...
Nov 13, 2016 | Dell Computers & Internet
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
Help, connection fails from wifi, after walking away from the wifi box
All WiFi "boxes", called WiFi routers, have a limited reach. That reach can be limited, when you are in a building with concrete walls and steel plating. But even when you have a free sight tot the router the range can be limited to 25 or 50 meters. Although manufactures say up to . Be aware other rower working on the same frequency, close to you also will limit the range of operation.
Mar 15, 2015 | Tablets & eReaders
Wifi not working
Could be your router, could be your laptop. If other devices can connect to your wifi, then it is your laptop, if not, then it is your router. If it is your router, check all physical connections and power of course, make sure it is plugged in. If it is your device, and all other devices cannot connect to the wifi at your place either, but can connect at other places with wifi, it is either your router, or your ISP. If it is your laptop, then you can perform a system restore, which may correct the problem. If that doesn't work, look up the support/drivers section for your particular model from the manufacturers website, down the drivers for your laptop Wifi card, and reinstall the drivers. The support section at the website will also show you how to perform a system restore.
Dec 04, 2013 | Toshiba Satellite Computers & Internet
I tried to connect my vaio to wifi it is showing limited axcess what should i do
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 26, 2013 | Sony VAIO Notebook
Why does my tablet keep saying authentication problem when trying to connect to wifi
Had same problem - said signal weak although strong on other devices, and hung on authenticating.
Cordless phone on base unit was beside wireless router. Moved unit and turned off phone. Problem disappeared, and signal showed strong.
Dec 30, 2012 | Archos Arnova 10 4GB 4)
Wireless connection problems
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 19, 2012 | HP Compaq nc6000 Notebook
I have to place my laptop near the router to get wireless connection
blower your wifi router and push a minny button that is placed on the corner of router
Jan 20, 2012 | D-Link (DSL-2640B) Wireless Router
Loss of wireless connection
Is your laptop able to connect to other networks? If so, your router maybe at fault. Reset the router, if it still doesn't work, you may need a new router. If your laptop has issues connecting to other networks, the wifi radio in your laptop may need to be replaced.
Jan 06, 2010 | Zoom X6 (5590) DSL Modem (55900003)
Toshiba equium A210-17i wireles problems
It doesnt sound like a problem with you laptop, rather its most likely to be the router.
People can edit the settings so that only their IP adress can connect.
If you can connect with limited connectivity, again its the router, not connecting properly.
Can you connect to any router? i take it you're not connection to your own XD
Ed
Feb 02, 2009 | Toshiba Equium 7100S PC Desktop
Open Questions:
Computers & Internet Logo
79 people viewed this question
Ekse
Marvin
Marvin
