Question about Janome Memory Craft 5700
Rolled hem I would like to make a rolled hem on crystal organza. Can you help?
    Genius:
  • 1,116 Answers
Here is a tutorial - http://www.wonderhowto.com/how-to-rolled-hem-foot-sewing-machine-240603/view/
I have to practice with scraps first.
Posted on May 08, 2010
Can I make rolled hem with a Juki MO 2366 N?
Most likely. Most overlockers can make a rolled hem. You will probably want to do a lot of practicing on scrap chiffon before trying it on the real thing. It involves using only one needle, both loopers, and making appropriate adjustments to the machine.
Serger 101 Threading the Juki MO 654de Machine for Roll Hemming by CKC...
How to Serge Rolled Hem
Serger Stitches 101 Cheat Sheet Never Ever Without It Your New Must Have...
Bernina has some very nice Serger Workbooks that could be helpful:
Bernina Mastery Workbooks
Nov 13, 2017 | Juki Sewing Machines
792d setting for rolled hem?
If you scroll down to "Serger," and download Workbook 1, there are instructions in there for setting up a rolled hem.
Your machine differs but the way it functions is very similar--at least the settings should be helpful.
Jul 18, 2017 | Sewing Machines
I am using a Bernette 303 overlocker for sewing organza hemproll. What is the settings to do a proper job? I don't have a manual Please help>
Hello Annelize Barnard
'sounds like you are after a rolled hem on organza. A very beautiful finish indeed.
Thread serger for 3-thread rolled hem. This video may be very helpful https://www.youtube.com/watch?v=bKZTa_kvDKQ
The needle tension will stay at the normal setting. The upper looper tension should be lowered by at least 2 and the lower looper increased by 2 ... these may be even more depending on the thread used. For best results use a "woolly" thread (woolly polyester is best as it will not melt with heat, although there are woolly nylon threads which are heat resistant). Test the settings on a scrap of the same organza.
Please let me know how this works for you.
Happy Rolling.
Feb 24, 2017 | Sewing Machines
How do i create a rolled hem using my Platinum 750?? Do i need a special presser foot?
by rolled hem I imagine that you are trying to put something like rope in the hem to make a round edge
You can buy a 1/2 foot that allows the needle to get close to what ever is making the roll
see your local sewing machine shop
Jul 07, 2016 | Platinum Sewing Machines
How do I create a rolled hem with this machine. I see the stitch width knob, but do I need to remove one of the threads for this?
Making a rolled hem on any overlocker is achieved in the following way:
use right hand needle only and top and bottom loopers. Turn stitch length down so threads are closed up (on mine this is 0.5). Your stitch length dial will be one on the right hand side near the flywheel usually. Loosen off the the top looper tension and tighten up the bottom looper tension (these are the right and 2nd right tension dials on front of the machine). On my Bernette I leave the needle at the usual 5, 2 on the top looper and 6.5 to 7 on the bottom looper thread. Move cutting blade position to the right so that you are trimming the fabric quite a bit wider than your stitch, this makes the fabric "roll" underneath inside the stitching to form the rolled edge or hem.
There is also another step that needs to happen where you change or remove a little stitch finger that sits in the pressure foot or just under it. On the Bernettes, you flick a lever to move this stitch finger back towards the operator so it is out of the stitch forming area. On some machines, it is a case of changing the little stitch finger which is screwed onto the pressure foot with a screwdriver.
I really don't know with your Necchi which it is but have a good look at the pressure foot, and around the blade cutting area and see if you can see a lever or check out the accessory bag and see if there is another stitch finger in there, it would be smaller than the one on the foot now. In effect, this finger sits out and the threads wrap around it to form your normal overlock but for rolled hem you want a much smaller finger in place to make a very little seam.
The other variable which makes a very neat job is to use a thread called "wooly Overlock" in the upper looper only. This thread when pulled under tension is tight looking but when you let it go, it fluffs out. So when seaming on a rolled hem it fills out the stitching and covers the edge of the fabric fully giving a smooth look. You can do it without but wooly thread makes a great job and you'll see it on all Ready to Wear seams usually for this reason.
If I am going to roll hem a fine sheer woven fabric like organza or chiffon I will change the needle to make sure it is nice and sharp and also ensure it is a regular point, not a ball point (I seam lots of knits so have ball points in most of the time on mine) Usually a size 80 is fine.
I hope this gets you going with your overlocker, I usually test stitch quite a bit with the stitch length at the normal 2.5 setting and adjust the looper tensions until I've got the stitch looking good, then turn it down to the very close 0.5, just to not waste a ton of thread.
Sep 09, 2011 | Necchi 6002 Sewing Machine
Juki baby lock EA 605 'rolled hem'
No way to rolled hem, machine as much as 40 years old
Aug 26, 2009 | Sewing Machines
How many foot for Baby lock E5280 like flat, blind, rolled hem?
i dont have a baby lock but on my machine i change from rolled hem to flat needle plate
or change setting to n from r also loosen lower looper tension as rolled hem requires a tight lower looper tension.
hope this helps you
mary h
Jan 05, 2009 | Baby Lock BL1556
Sewing Machines Logo
346 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
